Thomson tg585 v7 user.ini
- Re: Thomson tg585 v7 user.ini
30-08-2011 1:41 PM
anyways i have my old be broadband router and wanted to use that. Problem is I think the config is geared towards BE and not plusnet.
Can anyone provide me with a vanilla plusnet user.ini file with user log Ins stared out etc?
am writing this in my phone with appalling 3g so any help would be much appreciated
30-08-2011 4:34 PM
I can't provide you with the user.ini file directly but I can provide a link to all our firmware's hete:
http://community.plus.net/library/hardware/how-to-upgradedowngrade-the-firmware-on-the-thomson-585v7...
If you were to flash your current router (providing the router is an ST585v7 or ST585v8) you should be able to connect.
30-08-2011 7:44 PM
A couple of issues / questions tho
i run the flash app using the 585v7 8.2.23.0 firmware (which is already on there, but the BE branded brain), but it fails due to - the device did not respond anymore after upgrade
In the link you posted under things to consider it says about connecting the pc directly to the router. Mine due to necessity has a couple of switches in the way, tho not sure why that would cause problems.
any ideas? Researching this on my mobile is difficult to say the least
30-08-2011 8:05 PM
I've always set the PC to have a fixed IP when upgrading, though I don't think that is essential. The PC runs Windows XP, upgrading failed from Vista though I haven't tried with the latter OS recently.
I'd also suggest upgrading to version 8.2.6.5, despite the numbers that is the latest release for the 585v7.
30-08-2011 8:31 PM
Will try plugging the pc directly into the router in a mo.
Any other suggestions in case that doesn't work?
30-08-2011 9:32 PM
As Spraxyt says and the page Alex pointed you to, you have to have your connection wired for it to work.
Jojo
30-08-2011 9:43 PM
Its definitely a v7, not a v8, its wired not wireless
This is a strange one
30-08-2011 9:47 PM
31-08-2011 8:11 AM
31-08-2011 9:23 AM
In that case I'd say that your router is locked down to Bethere. You should have your ADSL modem before the end of the week.
I have also sent a returns bag to you for the Netgear WNR1000 modem we sent to you for your fibre connection. Once the service becomes available in the area we'll send out another modem for you.
