Technicolor 582n: Power light red
- Re: Technicolor 582n: Power light red
03-09-2014 12:09 PM
My router hasn't been working today. The power light is red and no other lights appear on the router. I've turned it off for 5 minutes and turned it on again but this is still the case.
What would be the recommended course of action? To use the pinhole at the back?
Message 1 of 5
(7,353 Views)
4 REPLIES 4
03-09-2014 12:16 PM
Sounds like it or the power supply is dead, have you had any thunderstorms recently?
I would get a replacement sent out as the only know red led you can ignore most times is the Internet one, as it can fail to show the correct state at times.
FTTP 500 regrade from Tues 28th November
Message 2 of 5
(7,062 Views)
03-09-2014 12:18 PM
Hi readjono,
I'll get a replacement sent out to you, the only thing that router will be good for now is a doorstop.
Dan.
Dan.
Message 3 of 5
(7,062 Views)
03-09-2014 12:18 PM
Oh no! So can I assume I do not need to do anything else?
Not aware of any storms here.
Message 4 of 5
(7,062 Views)
03-09-2014 12:39 PM
I don't think so, unless you know any special voodoo tricks to bring it back to life
The new router should be with you in the next day or two.
Message 5 of 5
(7,062 Views)
