TP-Link Deco X20 set-up
Capital
I've just bought 2 Deco X20 hub/routers to replace may aging D-Link.  The primary motivation was to set up a mesh system throughout the house.
Unfortunately I can't reach the internet through the Deco.  I go through the set-up procedures, guided by TP-Link's help desk, but although it sets up a local WiFi signal, it fails to connect to the internet.  I'm using an Openreach DSL.
Does anyone have experience of persuading Decos to talk to the net?
18 REPLIES 18
Fixes: 579
Re: TP-Link Deco X20 set-up
@Capital I assume that means youre connecting the X20 via an Openreach DSL modem.
You need to set the DEco INternet connection settings to PPPoE with your PLusnet username and password.
Username is <youracccountname>@plusdsl.net and the password is the one you use to access the member centre.
If the Deco has any option for VLAN ID then make sure its disabled
RealAleMadrid
Fixes: 68
@Capital  The TP-Link will work on Plusnet, but you need a VDSL2 modem to connect to the line. This could be an Openreach modem or the Plusnet Hub2 configured in Bridge mode which acts as a stand alone modem. What hardware have you tried?
Not clear what you mean by "an Openreach DSL🤔
Fixes: 478
@RealAleMadrid
As this has been posted on the Full Fibre board I am assuming that the @Capital is referring to the BT ONT, in which case this acts as the modem.
@Capital  I assume that you are on Full Fibre and not one of the FTTC products?
Capital
Ah, my mistake.  I have an FTTC connection.  Until now I wasn't aware of the distinction.  Sorry about that.
Fixes: 478
Moderator's note:
Thread moved from Full Fibre to Broadband
Capital
Thank you MisterW, disabling the VLAN option worked to get an internet connection.  Unfortunately it still doesn't provide internet through to my house cabling.  Not everything is WiFi.  TP_Link are looking into it.  Some documentation would be a huge help, but that's not the way these things are set up.
Fixes: 579
If you explain a bit more, maybe with a diagram of how the units are connected, we may be able to help
Fixes: 478
@Capital
Do you mean you have access to the Internet over the deco wireless SSID but not using wired devices plugged into the deco satellites?
Fixes: 579
@Capital there's a long thread about the problem here https://community.tp-link.com/en/home/forum/topic/209202?sortDir=ASC&page=1
Started in 2020 , last post in April this year! problem still exists...
Capital
Thanks MisterW.   That is indeed a long thread with no clear resolution. I've attached a sketch of the configuration ignoring the satellite Deco.   I was hoping to be able to distribute the Deco units at various points in the building linked by ethernet cables, rather than having to position them closer and relying on wifi to provide the backhaul function.  It would mean fewer satellites.
Fixes: 579
@Capital
So does the desktop if connected directly to the Deco work fine ? but not work through the switch
Is it a DHCP issue ? does a static IP on the desktop then work through the switch ?
What model is the switch ?
Fixes: 478
For what it's worth. I have set up a 3 unit M4 mesh for a friend. This consists of an EE hub with WiFi switched off and the M4s in Access Point mode (assumed necessary as there's a digital phone service running from the hub). The master M4 feeds an Ethernet switch. The other two M4s use Ethernet connections to the switch for the backhaul. One of the satellite M4s uses the second Ethernet socket to feed a computer.
@Capital
Have you tried putting the Hub 2 back and using the Decos in AP mode?
Fixes: 579
@Baldrick1 that would imply it is a DHCP problem. In router mode, the Deco is going to be the DHCP server, in AP mode it isnt.
Capital
Hi Baldrick1 - I don't have a Hub 2.  The Huawei modem is the one that BT supplied and I already had a functional router, so didn't take the offered Hub.
