TG585v8 bridge
Joncy92
TG585v8 bridge
Hello,
I've been looking for a way to get this old router into bridge. I found this post:
http://community.plus.net/forum/index.php/topic,95646.0.html
But the links to get the firmware for bridge mode are dead. Where else can I get it please? Thanks.
16 REPLIES 16
Fixes: 397
Re: TG585v8 bridge
Hi @Joncy92
If you're comfortable using the Telnet CLI, then I still have a pdf pf the 'Internet connection config guide' for Speedtouch routers. A section in it describes the CLI commands to setup bridged PPPoE. I believe these will work with the TG585, assuming you have access to it's CLI via telnet.
It's not for the faint-hearted though...
Joncy92
Re: TG585v8 bridge
Thanks mate! I can work with that!
Fixes: 397
Re: TG585v8 bridge
I've attached a copy
Section 4 is the one you want
Joncy92
Re: TG585v8 bridge
Cheers for the upload. Have already hit a roadblock.
Tried flushing the configs after resetting the router but I'm getting errors:
Some atm interfaces are still in use cannot be deleted.
Some atm phonebook entries are still in use cannot be deleted.
When trying to when the phonebook I get:
Failed to add entry.
Any idea why?
Fixes: 397
Re: TG585v8 bridge
You might have to detach  the atm interface before it can be deleted although I would have thought flushing the config would have done that
atm ifdetach ( i think! )
I've attached a copy of the full CLI interface ( it's for the TG582 but I suspect the 585 is VERY similar )
PS I've ot a couple of TG582's lying around, (can't guarantee it!) but if I get chance I'll try and configure one of those as a bridge and see what happens
PPS just looked at some of my config files lying around
might be worth trying the following commands before trying to configure
ppp relay flush
ppp flush
eth flush
atm flush
atm phonebook flush
Joncy92
Re: TG585v8 bridge
I got the errors I posted previously when flushing atm and phonebook.
I've made some headway now by using telnet menu, the config saved and I can see the atm and bridge configs under interface list command.
However I tried testing it via windows PPPoE client but I get error 651. See attached pic.
Fixes: 397
Re: TG585v8 bridge
try making sure the encaps is explicitly set to llc on the atm ifconfig.
Joncy92
Re: TG585v8 bridge
Already set to llc
Fixes: 397
Re: TG585v8 bridge
Make sure that your new atm phonebook entry is correct , the addr should be 0.38 and then check that the new atm interface is configured with the new phonebook entry
Just found an old thread https://community.plus.net/t5/Broadband/Using-the-Technicolor-TG582n-in-Bridge-Mode/td-p/901808 about bridge mode on the TG582 with the complete set of commands required
ppp relay flush
eth flush
atm flush
ppp flush
atm phonebook flush
atm phonebook add name=BrPPPoE_ph addr=0.38
atm ifadd intf=BrPPPoE_atm
atm ifconfig intf=BrPPPoE_atm dest=BrPPPoE_ph  encaps=vcmux ulp=mac
atm ifattach intf=BrPPPoE_atm
eth bridge ifadd intf=BrPPPoE_br
eth bridge ifconfig intf=BrPPPoE_br dest=BrPPPoE_atm
eth bridge ifattach intf=BrPPPoE_br
saveall
although there was a question whether encaps should be llc rather than vcmux. There was another thread recently setting up bridge on a tplink and that wouldn't work with vc-mux
Joncy92
Re: TG585v8 bridge
I cannot flush atm or phonebook.
When I try ifdelete or ifdetach I just get invalid interface. Yet I can use ifconfig on it.
Very strange.
Fixes: 397
Re: TG585v8 bridge
I can only assume then, that the 585 hasn't got quite the same cli facilities as the 582
Joncy92
Re: TG585v8 bridge
Cheers for all the help dude.
I've been messing around in telnet and managed to flush everything.
I can see PPPoE_br in the the management web page along with DSL now. They both say disconnected and I cannot get it working. Anything I've missed?
PS
System configuration shows service name: Routed PPPoA on 0/38
Fixes: 397
Re: TG585v8 bridge
I would have expected the DSL interface to come up straight away as long as the atm interface is correct .
That's just the default description of the old configuration, it's only text AFAIK  you can probably ignore that.
Joncy92
Re: TG585v8 bridge
Okay so I've tried connecting again via windows PPPoE and it doesn't work. Have also plugged the speedtouch from LAN 4 to the Netgear internet port (running dd-wrt) and that will not pick up a connection either.
Don't think this modem wants to play ball.
