Sync speed
- Sync speed
Sync speed
08-03-2014 11:58 AM
Re: Sync speed
08-03-2014 12:03 PM
what are the stats from your router - noise margin, speeds and attenuation (this explains how to get them http://community.plus.net/forum/index.php/topic,96155.0.html )
Re: Sync speed
08-03-2014 12:13 PM
Uptime: 1 day, 18:01:42
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 1,159 / 11,263
Data Transferred (Sent/Received) [MB/GB]: 351.95 / 4.34
Output Power (Up/Down) [dBm]: 12.9 / 0.0
Line Attenuation (Up/Down) [dB]: 20.4 / 37.5
SN Margin (Up/Down) [dB]: 6.0 / 6.8
Loss of Link (Remote): -
Error Seconds (Local/Remote): 14,566 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 46 / 46,639
HEC Errors (Up/Down): 42 / 25,881
Re: Sync speed
09-03-2014 7:33 PM
Latest stats as of 9 March:
Uptime: 1 day, 3:56:33
Bandwidth (Up/Down) [kbps/kbps]: 1,115 / 11,559
Data Transferred (Sent/Received) [GB/GB]: 2.50 / 6.42
Output Power (Up/Down) [dBm]: 12.8 / 0.0
Line Attenuation (Up/Down) [dB]: 20.5 / 37.5
SN Margin (Up/Down) [dB]: 6.2 / 4.3
Error Seconds (Local/Remote): 7,380 / 0
CRC Errors (Up/Down): 0 / 55,948
HEC Errors (Up/Down): 0 / 29,151
Re: Sync speed
10-03-2014 9:55 AM
You're getting good speeds when looking at the length of your line. Let us know if you do start to have any issues though.
Re: Sync speed
10-03-2014 12:48 PM
Estimated line speed:
18Mb (This may vary between 9Mb and 21.5Mb) - Checked on 2014-03-07 23:40:28
Current line speed:
21 Mb
Re: Sync speed
10-03-2014 12:57 PM
That's been updated for you and I've responded to your open tickets on your account.
Re: Sync speed
10-03-2014 1:16 PM
Re: Sync speed
10-03-2014 2:13 PM
I've submitted the request to turn interleaving off. This should take effect in the next 24 hours.
Re: Sync speed
11-03-2014 7:29 PM
Re: Sync speed
12-03-2014 2:29 PM
