Sync drops when phone rings (subject was "Is this a record?)
- Sync drops when phone rings (subject was "Is this ...
Re: Sync drops when phone rings (subject was "Is this a record?)
20-05-2013 4:51 PM
20-05-2013 4:57 PM
21-05-2013 9:31 AM
I've just tried swapping to a TG582n with 8.4.4.J firmware. To say the bit loading is odd is an understatement - think I'll try a resync!
21-05-2013 9:36 AM
[Edit] Looking at the graph again it's not tone 31 - not very clearly labelled.
21-05-2013 9:37 AM
21-05-2013 9:42 AM
{admin}=>xdsl debug bitloadinginfo
Tone : # Bits per tone
0 : 0 0 0 0 0 0 0 0 2 3
10 : 5 6 6 7 7 7 7 8 7 8
20 : 7 7 7 7 7 6 6 5 4 4
30 : 3 0 31 -27 32 80 0 0 0 0
40 : 31 -27 63 -4 9 10 10 10 11 11
50 : 11 11 12 12 12 12 12 12 12 12
60 : 12 11 11 12 0 12 11 12 12 12
70 : 12 11 11 11 11 11 11 11 11 11
80 : 11 11 11 11 11 11 11 11 11 11
90 : 11 11 11 11 11 11 11 11 11 11
100 : 11 11 11 11 11 11 11 10 11 10
110 : 10 10 10 10 10 10 10 10 10 10
120 : 10 10 10 10 10 10 10 10 10 10
130 : 10 10 10 10 10 10 10 10 10 10
140 : 10 10 10 10 10 10 9 10 10 10
150 : 10 10 10 10 2 10 10 10 10 10
160 : 10 10 10 10 9 10 10 10 10 9
170 : 10 10 9 9 9 8 8 8 8 9
180 : 8 8 8 8 9 8 8 8 8 8
190 : 8 8 8 8 8 8 8 8 8 8
200 : 8 8 8 8 8 8 8 8 8 8
210 : 8 8 8 8 8 8 8 8 8 8
220 : 7 8 8 8 8 8 8 8 8 7
230 : 7 7 7 7 7 7 7 7 7 7
240 : 7 7 7 7 7 7 7 7 7 7
250 : 7 7 7 7 7 0
21-05-2013 9:48 AM
21-05-2013 9:51 AM
0 : 0 0 0 0 0 0 0 0 3 3
10 : 5 6 6 7 7 7 7 7 8 8
20 : 7 7 7 7 6 6 6 5 4 4
60 : 12 12 12 12 0 12 11 11 12 12
70 : 11 11 11 11 11 11 11 11 11 11
100 : 11 11 11 11 11 10 11 11 10 10
140 : 10 10 10 10 2 10 9 10 10 10
150 : 10 10 10 10 10 10 10 10 10 10
160 : 10 10 10 10 9 10 10 10 10 10
170 : 10 9 8 9 9 8 8 8 9 9
180 : 8 8 8 9 9 8 8 8 8 8
220 : 8 8 8 8 8 8 7 8 8 7
250 : 7 7 7 7 7 0
Edit: I'm going to go back to the other TG582 with the latest firmware. Back in a bit.
21-05-2013 9:54 AM
Apart from Firmware, are they the same, both without USB ports?
21-05-2013 10:01 AM
10 : 5 5 6 7 7 7 7 8 8 8
20 : 8 7 7 7 6 6 6 5 4 4
30 : 3 0 0 0 0 0 0 6 6 7
40 : 7 8 8 9 9 10 10 10 11 11
60 : 12 12 11 12 0 12 11 12 12 12
100 : 11 10 11 10 11 10 11 11 11 10
170 : 2 9 8 9 9 8 8 8 8 9
180 : 9 8 8 8 9 8 9 8 8 8
220 : 8 8 8 8 8 8 8 8 8 7
250 : 7 7 7 7 7 0
Yep, identical boxes, neither has USB
21-05-2013 10:10 AM
What was your previous exchange line card? If you feel like experimenting more it would be interesting to see if the 8.4.4.J eventually rights the RS plot but whether it will hold connection on the Marconi card. I suspect not - but you never know.
Edit: you haven't tried the Netgear yet have you?
21-05-2013 10:16 AM
21-05-2013 10:42 AM
21-05-2013 10:47 AM
21-05-2013 10:52 AM
C:\Users\John>ping ntp.plus.net
Pinging ntp.plus.net [212.159.13.50] with 32 bytes of data:
Reply from 212.159.13.50: bytes=32 time=15ms TTL=249
Reply from 212.159.13.50: bytes=32 time=14ms TTL=249
Ping statistics for 212.159.13.50:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 14ms, Maximum = 15ms, Average = 14ms
Definitely fastpath!
