Sync Speed Down
- Sync Speed Down
Sync Speed Down
17-06-2014 11:04 PM
A few weeks ago I had problems with my electrics in the flat where I live resulting my sync speed go down from 79mb to 77mb. Is there anyway for me to get the 2mb difference back?
Message 1 of 3
(578 Views)
2 REPLIES 2
Re: Sync Speed Down
18-06-2014 12:10 AM
Quote from: thedoors27 A few weeks ago I had problems with my electrics in the flat where I live resulting my sync speed go down from 79mb to 77mb. Is there anyway for me to get the 2mb difference back?
Wait.
Don't keep disconnecting the modem/router trying to get it to pick up the extra sync, DLM may see these as errors and reduce your sync speed.
Just leave it, and see if DLM raises it at any point, if not, 2Mb isn't a massive difference at those speeds
Message 2 of 3
(368 Views)
Re: Sync Speed Down
19-06-2014 11:29 AM
Ok, I'll keep my eye on it. Fingers crossed it will go back up.
Message 3 of 3
(368 Views)
