Stuck Profile
- Stuck Profile
Stuck Profile
28-11-2011 9:56 AM
For months my profile has been 7.1mb despite sync speeds that should have given a higher profile.
From btspeedtester
Albeit it's not causing me any problems it does mean that this months ofcom/samknows figure will be low.
From btspeedtester
Quote Your DSL Connection Rate :10360 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 9139 Kbps
Message 1 of 5
(931 Views)
4 REPLIES 4
Re: Stuck Profile
28-11-2011 10:28 AM
I've just moved the profile up a notch to 7150 from 7000 from this end. However I'd expect better than that for a downstream sync 10360. Let me know if you'd like me to try an SNR reset as that may lead to some improvement for you.
Message 2 of 5
(440 Views)
Re: Stuck Profile
28-11-2011 10:42 AM
Thanks for looking at it Adam - as you say one would expect a much higher profile in line with bt tester.
Router currently showing
Let's see if there's an automatic improvement - as I said it doesn't affect my usage but there's another report due this month.
Quote DSL Type: G.992.5 annex A
Maximum Bandwidth (Up/Down) [kbps/kbps]: 20,977 / 11,140
Bandwidth (Up/Down) [kbps/kbps]: 448 / 10,360
Data Transferred (Sent/Received) [GB/MB]: 83.66 / 525.76
Output Power (Up/Down) [dBm]: 12.5 / 20.0
Line Attenuation (Up/Down) [dB]: 23.5 / 38.5
SN Margin (Up/Down) [dB]: 22.0 / 3.0
Vendor ID (Local/Remote): TMMB / TSTC
Message 3 of 5
(440 Views)
Re: Stuck Profile
29-11-2011 9:40 AM
Profile has now improved to 8mb
Message 4 of 5
(441 Views)
Re: Stuck Profile
30-11-2011 10:02 AM
Message 5 of 5
(441 Views)
