Streaming from laptop to tv issue
- Re: Streaming from laptop to tv issue
- « Previous
- Next »
12-11-2012 10:24 PM
Hi and thanks to all of you,
If I wasted some of your time, those of you who chipped in, my apologies. Sorry RR, the psu had not occurred to me, as it works fine in all other circumstances and has done for maybe a year now and I hadn't thought of switching the power plan down to test the connection :-[. Yes, Penfold, it was a mid-price cheapey(what was that about you get what you pay for?) and at last a friend turned up with their laptop which worked fine.
Again thanks for your efforts, consider this one solved
Message 61 of 62
(276 Views)
12-11-2012 11:01 PM
I'm really pleased you found the answer in the end. The solution is usually there if you have the patience and persistence to keep looking for it.
Message 62 of 62
(276 Views)
- « Previous
- Next »
