reset snr
- reset snr
reset snr
12-11-2012 4:30 PM
Hi, fortnight ago i removed all extensions, now i just have master socket with XTE 2005 pre-filtered faceplate with a 0.5m rj11 cable to router. Sync speed increased but snr is still high
could i please have a reset to see if i can gain more
ADSL Line Status
Connection Information
Line state: Connected
Connection time: 11 days, 11:30:16
Downstream: 3.844 Mbps
Upstream: 448 Kbps
ADSL Settings
VPI/VCI: 0/38
Type: PPPoA
Modulation: G.992.1 Annex A
Latency type: Interleaved
Noise margin (Down/Up): 15.0 dB / 22.0 dB
Line attenuation (Down/Up): 41.2 dB / 26.5 dB
Output power (Down/Up): 18.7 dBm / 12.3 dBm
ADSL Line Status
Upstream: 448 Kbps
ADSL Settings
VPI/VCI: 0/38
Type: PPPoA
Message 1 of 2
(555 Views)
1 REPLY 1
Re: reset snr
12-11-2012 4:36 PM
Message 2 of 2
(219 Views)
