Still i have rubbish speeds :(
- Re: Still i have rubbish speeds :(
06-08-2007 1:46 PM
http://portal.plus.net/central/forums/viewtopic.php?t=57746
I have my router plugged into the main socket by itself. No splitter box thingy, just directly into the wall. The router can't hold the sync speed for ****. This enquiry is a week or 2 old. its not the exchange as my next door neighbours speed is fine. My speed has been fine for at least the last year since i was maxed.
Also, i enquired last week why i had been charged for an extra 2gb of data when it was the first day of new month. See here:
http://portal.plus.net/central/forums/viewtopic.php?t=57921
I was told this was being looked into by Dave, but i havent heard anything back yet. Cheers guys
06-08-2007 1:53 PM
Doesn't look like you were actually charged for the extra usage, and there isn't an extra amount on this months either. This is due to the times the billing script runs, you will have gone over your usage from the previous month on the morning of your billing. This is then reset and you aren't charged.
06-08-2007 1:57 PM
06-08-2007 2:05 PM
Im just wondering, why now? Why after so long has my sync speed been up and down like a yo-yo?
It sits at 1500, then is steady & after a few days goes to 2500, then drops, then gores to 3500, then drops, then goes to 2500, then drops...
annoying! The person next door to me is having no issues at the moment at all (talktalk) so im just wondering after a year of no problems, why has this started now? Any ideas would be great m8. Thank you
06-08-2007 2:07 PM
Have you tried using a different filter?
06-08-2007 2:16 PM
All of a sudden it started dropping sync, unstable speeds etc etc.
So on Thursday past, i removed the extension lead, plugged the router directly to the master socket (nothin else attached this time, nor before) and the bt speed tester went to 3500 from 1500 or 2500 (cant remember). So i thought that must have been the problem, even though it had worked for months on the extension lead with no problems (which i found wierd).
Anyway, i see my speed has dropped again & im not getting the speeds i used to get previous to all this. What do you think m8?
06-08-2007 2:21 PM
Looking at the reports that we get from BT, it's been set to 2500Kbps since 04/08/2007 15:36:26. Dropped to that speed from the previous 3500 experienced on the 3rd.
I'd recommend keeping an eye on your synchronisation speeds over the next couple of days and see if you notice much in the way of fluctuations.
06-08-2007 2:26 PM
22-08-2007 12:44 AM
Speeds still rubbish, up and down like a yo yo on grabit graph.
Chatting to a chap from BT who was outside my house the other day. He was down the man hole thingy where the BT lines are. I asked him was the reson he was down the hole anything to do with why my broadband was ****** & was a nightmare. He asked which house was i in, i told him & he said no, that my line "looked" ok.
Anyway, this has been going on long enough now (over a month) & ive even changed the router from my linksys to a netgear. Was seeing a strange noise margin on the router yesterday, it read something like 21409876834 instead of the usual 10/12. Anyway, i reset the router & its grand now (back to 10)
Like i say after over a year of hassle free broadband (thumbs up Plusnet) its suddenly all started to go horribly wrong.
Cheers for reading guys, what is the next step?
22-08-2007 8:12 AM
22-08-2007 9:06 AM
22-08-2007 1:09 PM
Cheers guys
22-08-2007 1:13 PM
22-08-2007 1:46 PM
22-08-2007 2:44 PM
Make sure you have the latest firmware as some of the 3.01.X versions had problems will detecting the correct SNR and thought it had reduced, thus forcing a resync, when in fact it hadn't. for the dg834v1 & v2 the latest is 3.01.31 I think, the v3 has diferent hardware and thus different firmware revisions.
