Max---- New
- Max---- New
Max---- New
23-08-2007 8:55 AM
I think I have been maxd this morning(as requested) and my router shows
System Up Time 00:31:58
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN PPPoA 5554 6080 0 328 2857 00:30:30
LAN 10M/100M 6520 6035 0 2872 413 00:31:54
WLAN 11M/54M 78 0 0 5 0 00:31:45
ADSL Link Downstream Upstream
Connection Speed 1408 kbps 448 kbps
Line Attenuation 63 db 15.5 db
Noise Margin 6 db 11 db
A decent and improved connection speed but my speed on the speed tester still shows around 460 470
Am I understanding this properly ?? What should I expect ?? the line so far has been stable and I have disconected once Thanks E
Message 1 of 3
(1,453 Views)
2 REPLIES 2
Re: Max---- New
23-08-2007 9:04 AM
Because our profiles don't update in real time, I've just updated this to 1000Kbps for you.
Given the distance you are from the exchange, I wouldn't realistically expect you to get much more than this.
You'll need to reboot your router for these changes to take affect.
Message 2 of 3
(313 Views)
Re: Max---- New
23-08-2007 11:44 AM
You might want to plug your ADSL equipment into the BT Master socket to see if you get a higher sync. Or better still the test socket behind the user removable lower part of the Master socket.
If you get a better sync rate then your internal phone wiring or phones are affecting your speed.
You do have ADSL filters on all phones, faxes, sky boxes, alarms etc?
A filtered faceplate may help improve your speeds but assuming the DS line atten of 63dB is correct, you are a long way from the exchange so may not get much of an improvement with it. For £12 it may be worth a try.
Message 3 of 3
(313 Views)
