Static IP
MastaFool
Static IP
I wanted to order a static IP for my home broadband package, the account page says the 'add-on' is enabled but when I try and add or configure a static IP I'm unable to do so and it tells me to raise a ticket, but that page then says I'm unable to raise a ticket.
How would I get a static IP assigned?
5 REPLIES 5
Seasoned Champion
Fixes: 49
Re: Static IP
Hi @MastaFool welcome to the forums.
You do not need to configure with the static IP all you need to do is restart the modem/router. The members centre should indicate what your Static IP address is so you can check if its taken.
Dan.
MastaFool
Re: Static IP
Hi @Dan_the_Van ,
Thanks for the reply. When I try and look at the static IP in the member centre, I get the attached message.
Fixes: 367
Re: Static IP
@MastaFool
All you need to do is enter What’s my IP in Google to get the address.
Seasoned Champion
Fixes: 49
Re: Static IP
Hi @MastaFool
Thanks for the screen shot, from that I think you maybe trying to add the Static IP using this method
>Members Centre >Broadband >Static IP
Have you tried
>Members Centre >Add-Ons > Static IP
Hopefully that is the answer as that's where I see my Static IP address
Dan
MastaFool
Re: Static IP
That's the one... trust me to click on the wrong section 😁
Thanks for the help!
