Speeds slowing by the day
- Speeds slowing by the day
Re: Speeds slowing by the day
24-05-2013 10:38 AM
I'll stick with Matt's graphic and I'll not bother with a 72 hour run as my line is now almost fully stable.
Thanks for your time
24-05-2013 10:53 AM
You need to Telnet 192.168.1.254
The CLI command is syslog msgbuf show hist=enabled
Normal Telnet timeout is 60seconds, so you have enough time to Mark & Copy the screenful.
24-05-2013 11:19 AM
Won't be able to do this till tomorrow as I'm at work.
I did watch my SNR's last weekend via RouterStat and it was very respectable and steady 5 to 7 dB
My Router sync was also showing a very steady and consistent 6103. I'm hoping that the 4800 quoted by Matt isn't a reduced 6103 from last weekend !
24-05-2013 1:09 PM
I don't call 5 to 7dB very steady, but it does depends on how in particular, and when, it is varying. I'd like to see some of those jpgs - you can attach them to a post, can you post some up when you are home and have time.
To add an attachment to a post, if you didn't use the Reply button, when you've typed the message, click on Preview, then below the box you'll see the + Additional Options and Attachments..., click on the plus then Browse to where you saved the .jpg
25-05-2013 6:41 AM
Here is my RouterStat Connection speed last Sunday showing a very steady 6103 Downstream:
Here is my Noise Margin at the same time showing just under 5dB:
Fast forward one week and the PC has not been used all week:
Connection speed now down to 5534 and Noise Margin up to 9.9Db
Here is my Ookla via Plusnet BB speed last Sunday:
http://www.mybroadbandspeed.co.uk/results/190671341.png
and this morning:
http://www.mybroadbandspeed.co.uk/results/191003831.png
Router Status:
DSL Connection
Link Information
Uptime: 5 days, 9:16:54
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 440 / 5.534
Data Transferred (Sent/Received) [MB/GB]: 210,56 / 1,99
Output Power (Up/Down) [dBm]: 12,6 / 0,0
Line Attenuation (Up/Down) [dB]: 23,4 / 44,5
SN Margin (Up/Down) [dB]: 26,0 / 10,0
Loss of Framing (Local/Remote): 35 / 0
Loss of Signal (Local/Remote): 4 / 0
Loss of Link (Remote): -
Error Seconds (Local/Remote): 10.188 / 0
FEC Errors (Up/Down): 904 / 10.141.428
CRC Errors (Up/Down): 1 / 4.869
HEC Errors (Up/Down): 4 / 6.746
I have now have uptime of 5 Days plus (a first) but even so my speed has been reduced by BT WBC or whatever !!!
Why ?
I'll continue to monitor through the long weekend to see if my usage theory holds any water.
25-05-2013 8:06 AM
25-05-2013 8:37 AM
25-05-2013 8:53 AM
No problem with PhotoBucket for me
thanks
25-05-2013 9:08 AM
25-05-2013 10:30 AM
The problem with external servers is they can take a long time to load sometimes, they go down, images get deleted - so anyone searching in future where information in a thread like this would help, they could have an imageless thread to read
I'll just study all the data for a moment as something doesn't seem quite right, but some encouragement is that the SNRM "flatness" looks promising. I'll post back a bit later - don't bother with sync graphs that are completely flat and showing no deviation or change.
25-05-2013 10:42 AM
Link Information
Uptime: 0 days, 0:10:35
Bandwidth (Up/Down) [kbps/kbps]: 440 / 5.691
Data Transferred (Sent/Received) [MB/GB]: 219,93 / 1,99
Line Attenuation (Up/Down) [dB]: 23,3 / 44,5
SN Margin (Up/Down) [dB]: 25,5 / 3,7
Error Seconds (Local/Remote): 10.819 / 0
FEC Errors (Up/Down): 161 / 1.733.130
CRC Errors (Up/Down): 0 / 1.010
HEC Errors (Up/Down): 0 / 561
Recorded Events
Time Message
Info May 25 10:31:37 LOGIN User admin logged in on [HTTP] (from 192.168.1.64)
Warning May 25 10:31:17 IDS scan parser : tcp port scan: 23.62.53.73 scanned at least 10 ports at 87.115.91.70. (1 of 1) : 23.62.53.73 87.115.91.70 0040 TCP 80->58572 [...R..] seq 3102327524 win 0
Info May 25 10:22:55 CONFIGURATION saved by TR69
Info May 25 10:22:40 FIREWALL event (1 of 1): deleted rules
Warning May 25 10:22:40 PPP link up (Internet) [87.115.91.70]
Info May 25 10:22:40 PPP CHAP Chap receive success : authentication ok
Info May 25 10:22:39 PPP CHAP Receive challenge (rhost = ptw-ag04)
Info May 25 10:22:37 PPP CHAP Receive challenge (rhost = bras-red7.sl)
Info May 25 10:22:35 xDSL linestate up (ITU-T G.992.5; downstream: 5691 kbit/s, upstream: 440 kbit/s; output Power Down: 17.9 dBm, Up: 12.6 dBm; line Attenuation Down: 44.5 dB, Up: 23.3 dB; snr Margin Down: 3.2 dB, Up: 25.7 dB)
Info May 25 10:22:09 xDSL linestate down
Info May 25 10:21:43 xDSL linestate down
Warning May 25 10:21:32 PPP link down (Internet) [87.114.50.219]
Info May 25 10:21:13 xDSL linestate down
Info May 25 10:20:51 xDSL linestate down
Info May 25 10:20:35 FIREWALL event (1 of 1): modified rules
Info May 25 10:20:35 FIREWALL event (1 of 1): created rules
Info May 25 10:20:35 xDSL linestate down
Info May 25 09:40:57 SNTP Synchronised to server: 212.159.6.10
Info May 25 08:58:30 LOGIN User admin logged in on TELNET (192.168.1.64)
Info May 25 08:58:27 LOGOUT User admin logged out on TELNET (192.168.1.64)
Info May 25 08:40:57 SNTP Synchronised to server: 212.159.13.50
Info May 25 08:37:57 LOGIN User admin logged in on [HTTP] (from 192.168.1.64)
25-05-2013 11:30 AM
There would certainly seem to be a lot of noise still present after this resync as the SNRM is lower at 3.7dB and a high CRC count.
A couple of questions, is the RSL sample time definitely 10 seconds? Does the timing of the SNRM changes and sync loss co-incide with the use of anything electrical in your location that you might be aware of? (Don't live very close to an electrified railway line? - just trying to eliminate any silly possibilities).
When was the last time you switched off/rebooted the modem/router - might be able to deduce that from previously posted/saved DSL stats if you don't remember?
25-05-2013 11:57 AM
25-05-2013 12:02 PM
At that time the wife was on the phone (Modern Panasonic Cordless) but, she's at home most of the time and she's been on the phone quite a lot over the last 5 days (incoming and outgoing calls) with no issues.
At the moment I'm running at about 6.5dB and connection of 5650.
Looking at my stats, yes I have the occasional disconnection but it seems that BT's DLM is punishing me for it.
Q: This SNR of 6.5dB - is this good or bad and what is better higher or lower?
25-05-2013 12:03 PM
Thanks, the phone was in use at the time. But as above, it's been in use most of the last 5 days without issue.
I've just looked at the phone stats and the phone call was received at 10:23 which looks like one minute after the disconnection if I'm reading the logs correct ?
