Speed steadily dropping for last few days, and lots of downstream errors
croggy
Hi there, I'm currently using a TP-Link VR2100 router to connect to FTTC. It's been rock solid until the last few days, I've been experiencing dropouts and a noticeable drop in speeds. Current rate has gone from near to 90000kbps to 70000 just recently. Is anyone able to help with this?
Thanks,
Craig
7 REPLIES 7
Fixes: 334
Re: Speed steadily dropping for last few days, and lots of downstream errors
If the phone test passes, report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
croggy
Sadly I don't have a landline handset to hand, have swapped out all the cables and filter until I can pick one up tomorrow. Will see how it goes over tonight and tomorrow. Cheers for the swift reply!
willcutforth
Fixes: 113
Hey there @croggy how are you doing? How's the connection been?
 Will Cutforth
croggy
Speed still down compared to where it was, but has been stable. Got a landline phone arriving today (haven't used one in years!) so will be able to do quiet line test etc then Smiley
willcutforth
Fixes: 113
I can't remember the last time I used one as well haha! Would feel like going back in a time machine!
Let me know when you get it and if it shows as fault.
 Will Cutforth
croggy
Quiet Line Test passed with flying colours. Although, in typical fashion, my connection has been stable since I posted here Wink
If it remains stable will DLM ramp back up after a bit?
willcutforth
Fixes: 113
Always the case, like when you go to the doctors and you say you have pain and they ask you how it is now and you can't tell them because it's not there.
It should kick it back in but if it doesn't I will give it a kick up the back side. Just drop a message on here or PM whatever suits.
 Will Cutforth
