Speed problem - Gel
- Re: Speed problem - Gel
Speed problem - Gel
23-12-2010 3:59 PM
Have tried a manual disconnect/reconnect but still same.
Was wondering if it's because of heavy www use today; I'm around 2 1/2 miles from Exchange.
_____________________________________________________________________________
System Up Time 06:51:09
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN PPPoA 2254 2385 0 178 624 00:52:11
LAN 100M/Full 41457 36672 0 1280 762 06:50:52
WLAN 54M 96552 78902 0 3987 689 06:51:09
ADSL Link Downstream Upstream
Connection Speed 1376 kbps 448 kbps
Line Attenuation 61.0 db 31.5 db
Noise Margin 21.5 db 16 db
[Moderator's note by Jim (Oldjim) topic split off and title changed also excessive smilies removed ]
Re: Low speeds and line noise
23-12-2010 4:12 PM
23-12-2010 4:30 PM
My Netgear DG834G V5 plugged into dedicated ADSL socket which in turn wired directly to BT
Socket ie doesn't share phone cabling within house.
Never had this happen before, so will keep monitoring.
Possibly something at Exchange I guess, but Exchange Checker shows all OK...apparently
Old Jim.
23-12-2010 4:35 PM
I don't suppose you know what your noise margin is normally like?
Yours looks really high.
23-12-2010 5:11 PM
Is there anything you can do to check my profile?
23-12-2010 5:15 PM
I've just tried resetting this (as I'm not seeing any errors on your connection).
Let us know if you see any improvement in the next hour or so.
23-12-2010 5:31 PM
Shut router down for 10 minutes, opened up my other laptop, and now see best d/load speed ever,
despite that high SNR.
There is no noise on the phone line incidentally; is crystal clear.
New Stats:
System Up Time 00:02:50
WAN PPPoA 512 486 0 1395 1437 00:02:29
LAN 100M/Full 0 0 0 0 0 00:02:33
WLAN 54M 839 842 0 1948 1497 00:02:50
Connection Speed 3488 kbps 448 kbps
Noise Margin 6.0 db 16 db
Thanks Santa
Though speed checker still sees as:
Download Speed
1504 Kbps
0 Kbps 2000 Kbps
Max Achievable Speed
Download speedachieved during the test was - 1504 Kbps
For your connection, the acceptable range of speeds is 400-2000 Kbps.
Additional Information:
Your DSL Connection Rate :3488 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 1750 Kbps
Hopefully I may now be in learning period, and will see my profile at exchange lifted up
24-12-2010 2:59 PM
You just had to wait for the BT profile to lift. That has now, so you should see it up to 2500k now.
Jojo
24-12-2010 3:51 PM
Glad I had the problem.
Unfortunately on my IE8 image of speed test doesn't render properly; OK on Orca
24-12-2010 4:13 PM
12-01-2011 9:17 PM
ie
Estimated line speed:
1.0Mb (Accurate to within +/- 1Mbit) - Checked on 2009-01-12 20:58:11
Current line speed:
2000
Will it be staying there.?
Would reducing my SNR have any effect seeing data below, and when do +Net implement;?
here's my Router data:
System Up Time 23:04:01
WAN PPPoA 3909 3971 0 400 966 00:43:36
LAN 100M/Full 67953 74170 0 527 262 23:03:44
WLAN 54M 51819 38852 0 416 92 23:04:01
Connection Speed 3040 kbps 448 kbps
Line Attenuation 62.0 db 31.5 db Noise Margin 8.0 db 17 db
12-01-2011 10:16 PM
I know you said it was a dedicated adsl port but have you actualy tried the test socket, I assume by 2.5 k/m from exchange you mean pysicaly as oppsed to your line length im supprised with an attenuation that high you can even get the speeds you have.
Aslo your WAN uptime is only 43 minutes, have you been reconnecting or turning your router off? this can cause your ip profile to drop as BT see this as a stability issue and try to compensate by lowering your profile speed (annoying eh?)
13-01-2011 1:52 PM
Looks like you've had quite a few disconnections which have caused your profile to drop. Have a look here for hwo to troubleshoot a dropping connection.
Jojo
dick:green missing link inserted
14-01-2011 7:46 PM
(As your graph shows :(()
Current router stats are:
System Up Time 10:18:06
WAN PPPoA 1907 1955 0 670 1958 00:12:11
LAN 100M/Full 15745 18286 0 259 148 10:17:49
WLAN 54M 104316 87323 0 2291 570 10:18:06
Connection Speed 3136 kbps 448 kbps
As others have commented considering distance I am from exchange I'm surprised sometimes at speed
I enjoy.
Recall in dial up days BT did turn up the "gain" as I recall to enhance dial up speed, and that
may still be on line.
Speed Test Results
Date 14/01/11 19:41:27 Speed Down 1886.71 Kbps ( 1.8 Mbps )
Speed Up 376.94 Kbps ( 0.4 Mbps )
Port 80
Server speedtest1.thinkbroadband.com
15-03-2011 8:25 PM
a few disconnections too.
See my Plus Net profile has changed from 2.5 to 2.0; can we try & rest to
the previous figure of 2500 please?
New Profile:
Current line speed: 2 Mb
