Speed permanently lowered
IngeJones
We have the 80/20 package and as of a few weeks ago we've been capped or throttled at 13 Mbps.
35 REPLIES 35
Fixes: 387
Re: Speed permanently lowered
Which router are you using, please?
IngeJones
TP-Link Archer VR600 v3.   Tried restarts etc, checking QoS settings.  There is of course the heatwave to consider but I thought it might not hurt to also check if there is anything the plusnet end on our settings.
Fixes: 387
OK. I was hoping you were going to say a PN Hub2.
As you didn't, please report a fault via: https://www.plus.net/help/report-a-problem/
PhilipHeyes
Seasoned Champion
Fixes: 21
Disable QoS on a domestic grade router, it can degrade the speed.
The 13 Mb/s was measured how e.g. via Wi-Fi at the end of the garden or on a direct network cable to the router ?
IngeJones
We have had the QoS settings for at least two years now without this problem and we do need them.  Like I say it's not been a problem before
Fixes: 387
As asked above, is this via a wired or wireless speed test? Your connection stats suggest you should be getting close to the max speed.
ExForce9
Seasoned Pro
Fixes: 10
@IngeJones  do you have a STATIC IP address ?
Fixes: 387
@ExForce9 I don't know what relevance that has if this is a recent speed reduction?
IngeJones
Both ethernet and wifi...  which is actually a bit odd if the test is from device to test server.  Even though we do have some pretty good wifi
IngeJones
Yes we do have a static public IP
Fixes: 387
Are you testing on a wired connection, @IngeJones ?
Have you reported the issue?
As i said above, you are reporting a near perfect connection speed on a good line, so something is awry.
does your router have a useful event log?
ExForce9
Seasoned Pro
Fixes: 10
@IngeJones
As you have a static IP, then it is possible that your Plusnet "Current Line Speed" profile has got out of step with the Openreach BRAS profile, and could cause the restriction of speed that you are experiencing.
If you login to the Plusnet Member Centre,  what does your "Current Line Speed" say that is set to ?
IngeJones
Yes I got a call back from them just now and we're pretty sure it's not something set wrong plusnet's end.  I have a few more things I can try - including testing with a different router
ExForce9
Seasoned Pro
Fixes: 10
@IngeJones
Assuming that your connection is on FASTPATH (i.e. not interleaved) your Plusnet "Current Line Speed" should be around 77300Kbps
