Speed much lower than estmated speed..
- Speed much lower than estmated speed..
Re: Speed much lower than estmated speed..
25-02-2013 2:17 PM
25-02-2013 2:22 PM
An engineer is scheduled to go out tomorrow morning. I'll let you know what work is carried out as soon as I get it
25-02-2013 2:28 PM
26-02-2013 4:02 PM
26-02-2013 4:09 PM
Sorry about this.
26-02-2013 4:29 PM
26-02-2013 4:33 PM
I'll keep pushing
26-02-2013 4:43 PM
Just wondering what they have done with regards to the length of sub-standard cable, and as what this suddenly mannifesting fault they found on Monday is.
27-02-2013 11:04 AM
Sorry for the continued pestering, but is there any updates on this. I ask because im working away from home this week, and the wife passed comment this morning that the internet wasnt working last night, she said it just brought up a "Plusnet Login" screen. Without physically being there I am unable to investigate this, but with BT out looking/working on the external line yesterday, it seems more than a coincidence.
Many Thanks
27-02-2013 12:24 PM
Really sorry that you've been having problems with your connection. I've taken a quick look at your connection and it looks as though the password being entered into the router upon set up is incorrect. The connection may have dropped due to the work been carried out in the area.
More to follow regarding the work that has been done this evening for you. If you could ensure that all details being typed in are correct, then you should be able to use the service as normal.
27-02-2013 12:46 PM
27-02-2013 5:12 PM
The engineer has measured your line, but I am working late this evening with the escalation owner as we believe that we need another engineer to come out as we need to have the cabling between the Green Cabinet and your DP (Distribution Point - Telephone Pole) both measured and checked for quality. We are trying to dig a bit deeper to find out why some line tests fail and other pass, so this is continuing work.
When I know when the engineer is due to go back out again, I'll let you know, but it is important that everything is checked thoroughly. I'm sorry more wasn't done on the day, however, I think we are now pushing towards the correct side of the network now as I believe that this is where most of the speeds are being lost. I will keep you in the loop once I know more.
27-02-2013 5:48 PM
27-02-2013 6:28 PM
FAO Chris`s Manager.
I would just like to convey my appreciation and genuine thanks for the hard work and fantastic service that Chris has provided. I understand how frustrating working with BT can be at times, and how easy it would be to say that no more can be done, just to end the difficult work that usually entails chasing a fault. We are usually quick enough to complain when we feel that we have not received the service we feel entitled to, but on this occasion I would just like to point out to you what a pleasure it has been to deal with Chris. I appreciate the many long hours of dealing with BT (No doubt banging his head against the wall) that Chris has had to contend with, and to emphasise what a asset Chris is to both your team, and Plusnet as a whole.
Many Thanks
28-02-2013 11:32 AM
