Speed issues
- Re: Speed issues
Speed issues
21-11-2011 10:09 PM
For some reason my Ip profile has been dropped to 500kbps.
I watch a lot of on demand stuff bbc iplayer, 4OD etc but now its virtually impossible to watch.
here are my results
Link Information
Uptime: 0 days, 1:35:27
DSL Type: G.992.1 annex A
Channel mode: Interleave
Maximum Bandwidth (Up/Down) [kbps/kbps]: 1,108 / 10,016
Bandwidth (Up/Down) [kbps/kbps]: 448 / 8,128
Data Transferred (Sent/Received) [kB/MB]: 0.00 / 20.35
Output Power (Up/Down) [dBm]: 12.0 / 11.5
Line Attenuation (Up/Down) [dB]: 3.5 / 7.0
SN Margin (Up/Down) [dB]: 25.0 / 12.5
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Link (Remote): 0
FEC Errors (Up/Down): 0 / 34
CRC Errors (Up/Down): 0 / 3
HEC Errors (Up/Down): 0 / 4
Postcode:
Phone exchange:
PONTYBODKIN
Estimated line speed:
7Mb (Accurate to within +/- 1Mbit) - Checked on 2011-01-22 00:00:31
Current line speed:
0.5 Mb
Test1 comprises of Best Effort Test: -provides background information.
Download Speed
422 Kbps
0 Kbps 500 Kbps
Max Achievable Speed
Download speedachieved during the test was - 422 Kbps
For your connection, the acceptable range of speeds is 50-500 Kbps.
Additional Information:
Your DSL Connection Rate :8128 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 500 Kbps
please help
Lee
here are my results
Link Information
Postcode:
Phone exchange:
PONTYBODKIN
Current line speed:
0.5 Mb
Download Speed
422 Kbps
0 Kbps 500 Kbps
please help
Lee
Message 1 of 9
(1,511 Views)
8 REPLIES 8
Re: Speed issues
22-11-2011 9:39 AM
Hi Weetos,
I've had a look at your account. The speed profile has dropped in reaction to the connection dropping fairly frequently so we'll need to get to the bottom of that particular issue.
I can see a fault ticket is open but you've not answered all the questions, I'd advise going back to https://portal.plus.net/apps/kbdfaults to complete the requested info so we can look into that for you.
Message 2 of 9
(723 Views)
Re: Speed issues
22-11-2011 9:45 AM
I did notice a BT van parked by the exchange and the locak junction box over the past few days. I don't normally loose connection frequently. Could whatever work they were carrying out have affected my connection?
Message 3 of 9
(723 Views)
Re: Speed issues
22-11-2011 11:21 AM
Message 4 of 9
(723 Views)
Re: Speed issues
22-11-2011 12:43 PM
i have completed the fault ticket however i was only able to complete 2 speed tests (work got in the way lol)
Message 5 of 9
(723 Views)
Re: Speed issues
22-11-2011 5:35 PM
My ip profile has now been changed but i'm sill getting sub 1/2 meg speeds
IP Profile for your line is - 7150 Kbps
Message 6 of 9
(723 Views)
Re: Speed issues
22-11-2011 5:48 PM
ROUTER INFO
Uptime: 0 days, 21:22:40
Data Transferred (Sent/Received) [kB/MB]: 0.00 / 58.99
SN Margin (Up/Down) [dB]: 25.0 / 13.0
Error Seconds (Local/Remote): 37 / 0
FEC Errors (Up/Down): 21 / 233,836
CRC Errors (Up/Down): 28 / 2,428
HEC Errors (Up/Down): 27 / 79,393
Message 7 of 9
(723 Views)
Re: Speed issues
23-11-2011 1:03 PM
Hi weetos,
That looks a lot better, speed is set to 7150 on both ours and BTs side so you should be getting top speeds - hope that's the case now
Message 8 of 9
(723 Views)
Re: Speed issues
23-11-2011 5:58 PM
Yep all seems to be sorted now
my nestdoor neigbour said there were hevy roadworks taking place right next to the BT juction cabnet not 100 yrds from my house at the weekend, I suspect the noise is what caused my problems
Thanks for the swift action.
Message 9 of 9
(723 Views)
