Speed dropped....
MartinConnolly
Speed dropped....
I've unplugged my router a couple of times recently with thunder about (I lost a router once to lightning so I'm always wary now). Anyway, the speed has dropped down to about 33mbps instead of nearly 50. Could someone rest the line please? TIA.
6 REPLIES 6
MartinConnolly
Re: Speed dropped....
Moderators, could I have a DLM reset on my line please? Thanks.
Fixes: 387
The mods can't do that - they do not work for Plusnet. You will have to contact Customer Support.
MartinConnolly
Ok will do
Fixes: 387
It was possibly one of the Help Team, who do work for PN, but they do not usually respond to PM's, and the support routes have been tightened up.
@MartinConnolly
I believe this is now resolved?
https://community.plus.net/t5/Broadband/Broadband-disconnects-randomly-and-when-phone-is-used/m-p/20...
Not really helpful posting the same question across two threads, it is also against forum rules.
MartinConnolly
Yes, I didn't mean to, I was just looking for the contact name and realised he had said to update that other thread if necessary. Apologies for breaking the rules.
