Speed Tumbled
- Speed Tumbled
Speed Tumbled
27-09-2012 2:50 PM
Hey!
I've only been connected for 2 weeks, but previously I was getting sync into the 15000 range. Over the last few days I've been losing connection randomly, and sync has dropped to mid 11000s.
Am I getting a decent speed for my line?
Link Information
Uptime: 0 days, 17:50:54
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 828 / 11.705
Data Transferred (Sent/Received) [MB/GB]: 161,33 / 1,99
Output Power (Up/Down) [dBm]: 12,2 / 20,9
Line Attenuation (Up/Down) [dB]: 11,5 / 24,0
SN Margin (Up/Down) [dB]: 7,2 / 8,3
Chipset Vendor ID (Local/Remote): BDCM / TSTC
Loss of Link (Remote): -
Error Seconds (Local/Remote): 61 / 0
FEC Errors (Up/Down): 7.662 / 173.881
CRC Errors (Up/Down): 6 / 84
HEC Errors (Up/Down): 5 / 1.549
Link Information
Message 1 of 6
(1,055 Views)
5 REPLIES 5
Re: Speed Tumbled
27-09-2012 3:52 PM
I'm not sure if you've noticed yourself but the connection appears to have been dropping quite a lot recently which may have led to a lowering of the IP profile.
Have you been rebooting the router yourself at all? Otherwise I'd say that those line stats don't really indicate a problem.
Message 2 of 6
(441 Views)
Re: Speed Tumbled
27-09-2012 4:04 PM
Quote from: apjashley1 Over the last few days I've been losing connection randomly,
Message 3 of 6
(441 Views)
Re: Speed Tumbled
27-09-2012 5:54 PM
Quote from: _Adam_Walker_ Have you been rebooting the router yourself at all? Otherwise I'd say that those line stats don't really indicate a problem.
I have done a few manual reboots, when I saw a low sync and thought if I rebooted I'd get back to where I was before. But mostly I've had a look at that page and seen low uptime and it's disconnected for some reason external to my tinkering!
Message 4 of 6
(441 Views)
Re: Speed Tumbled
27-09-2012 6:46 PM
...and it's just gone down again, coming back up with less than 10K sync!
Uptime: 0 days, 0:00:58
Bandwidth (Up/Down) [kbps/kbps]: 828 / 9.791
Data Transferred (Sent/Received) [MB/GB]: 81,06 / 1,21
SN Margin (Up/Down) [dB]: 10,1 / 15,0
Loss of Framing (Local/Remote): 8 / 0
Loss of Signal (Local/Remote): 1 / 0
Error Seconds (Local/Remote): 28 / 0
FEC Errors (Up/Down): 16 / 5
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): 0 / 0
Download speedachieved during the test was - 7.55 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is - 8.45 Mbps
Message 5 of 6
(441 Views)
Re: Speed Tumbled
28-09-2012 9:24 AM
The disconnections are definitely more frequent too now so we'd advise raising a fault: http://faults.plus.net
Message 6 of 6
(441 Views)
