Slow speed last 48 hours
- Re: Slow speed last 48 hours
27-10-2010 7:58 AM
27-10-2010 9:38 AM
27-10-2010 11:14 AM
Might alleviate the problem a little, (of course, it may have no affect but nothing ventured etc.)
B.
27-10-2010 12:26 PM
27-10-2010 5:20 PM
Quote from: jelv Even if it doesn't change the VP it would still be worth trying as it also gives higher priority on the BT network.
I was under the impression that the Pro package I'm on was a prioritised bandwidth (we prmarily use the internet for evening gaming) - is that not the case? If it's not, then I have no idea why I'm paying so much each month lol.
Approaching 6 weeks of unusable evening broadband makes me open to any suggestions
27-10-2010 5:36 PM
27-10-2010 5:42 PM
It gives you:
832K upstream instead of 448k
Increased priority over the BT backhaul (before it hits Plusnet)
Ordinarily, it's #1 that people are interested in, and #2 has very little effect as there is generally enough backhaul capacity in place. However, in your situation #2 is the desirable reason for the upgrade to Max Premium.
Having the Pro product increases your priority over the Plusnet network, and thus you should be seeing line-speed at all times.
All it needs is a friendly Digital Care member to see the thread and to decide whether Max Premium would be a good idea.
Cheers
B.
27-10-2010 6:54 PM
JoJo... when you're back from your few days off, any chance you can look into that for me please?
Thanks again guys.
28-10-2010 10:40 AM
I have ordered the Max Premium for your line. This normally takes 24 hours to apply, so if there is going to be any improvement you should see it tomorrow night. I do hope this helps, caryn.
Jojo
28-10-2010 2:45 PM
The latest update on my ticket says "BTW update - We are currently waiting for a regrade to be started but have been advised that there is a delay due to No A-End Bearer Capacity " . Your tech support told me this means the exchange is being upgraded to 21CN , hence the delay. I don't understand how this is relevant to the fault I've reported. Iisn't that a normal planned upgrade rather than to fix the fault? It's making me very nervous that BT may not bother with my fault at all whilst they decide when this work will be done - that could take months
Am I understanding that correctly?
28-10-2010 3:07 PM
"A-End" usually means 'customer end', as opposed to 'ISP end'. I'm fairly sure the move to Max Premium does not require a physical retermination, but it will require a 'logical' retermination in the fact that at the exchange, your data will be routed over a slightly different pathway to get to Plusnet. This message seems to indicate there is no capacity to move you over.
Not a great position, but it does likely mean that this exchange is high on BT's list of priorities. However, CSC may be able to provide further information
B.
29-10-2010 9:05 AM
Wonder if BT will have actually moved along any further when they update today, or if they're still 'monitoring' lol
Cheers JoJo
29-10-2010 9:25 AM
I do hope it makes a difference. I'll take a look later and see if there have been any updates and let you know.
Jojo
30-10-2010 9:41 AM
Seriously, if that speed holds out, I'm more than happy to wait till BT can get it sorted properly at the exchange.
So far so good, thanks JoJo.
31-10-2010 10:12 PM
