Slow Speed's and drop outs daily!
darrenkeen19
My Normal DL is around 26ish, however BTWholesale shows I could get maybe 44mb, any way I could get my speeds tweaked upwards?.
also I get drop outs roughly a couple of times a day, not caused by WiFi dropout, as everything is connected to my PC by Ethernet ( BB drop's out at the router ( Hub One now, but bt Hub 6 Normally ) for around 5 mins at a time, no pattern, no warning, which I know is effecting my router's stability and overall speed connection.
Line state:Connected
Connection time:0 days, 21:01:46
Downstream:33.67 Mbps
Upstream:5.925 Mbps
I know what I can do to the account to check things, and the staff member who picks this up will also realise ;).
help a fellow Man out to see if he can squeeze a little more out and maybe a bit of stability as well.
5 REPLIES 5
Fixes: 357
Re: Slow Speed's and drop outs daily!
@darrenkeen19 Welcome to the forums. It would be helpful if you had posted all the screen of the 'btw.png' and the 'Advanced Diagnostics' from the 'btspeed.png' - vital information is missing.
Can you also post the WAN logs from your Hub - I suspect they will show repeated DSL drops.
darrenkeen19
Added New Screenshots
Wan log is from a while ago but shows 2 x drop
Fixes: 357
Something looks strange on your speed test - your IP profiles look like (to me, latish at night) to be ADSL ones, although you are achieving a poor  FTTC download speed, and a reasonable U/L. Are you on Fibre Unlimited or Fibre Unlimited Extra?
The WAN log is useless - I'm afraid we need a current one.
darrenkeen19
I will add a new wan log tomorrow, only put the hub one back on late last night.
I should be on Fibre unlimited Extra but was told I could not get it so was put on Fibre Unlimited.
thanks for your replies so far John Smiley
Fixes: 357
Quick comment - with the attainable speeds reported in the BTW screen shot, the 'Extra' is not worth the added cost - you are too far from the cab to benefit.
