Slow FTTC connection, DLM reset request
Sparxoo
Hi all,
My relatives VDSL connection has been flaky for some time. We appeared to fix it back on BT where OR came and replaced everything from NTE5 to pole.
Joining Plusnet, it appears to have gone a bit pants again for some reason (a company has been here fitting full fiber, so entirely possibly they've disturbed something on the pole). The only other thing I could think of, after reading online, was to change the DSL cable from the massive long coil of un-twisted phone cable, to a CAT5E twisted pair cable, that is just long enough to go between router and socket (with a single twisted pair carrying the signal). The router lives in the TV corner, with lots of power cables/adapters, and its unfortunately not able to be relocated elsewhere.
It appears to have synced now back at 34.999 down and 7.2 up, which is higher than it was connected at previously, but can the DLM/management be reset so we can try again from the highest speed we're meant to get? Is it best to phone, or can someone contact me on here and do it this way?
Cheers!
8 REPLIES 8
Fixes: 480
Re: Slow FTTC connection, DLM reset request
@Sparxoo wrote:
..The only other thing I could think of, after reading online, was to change the DSL cable from the massive long coil of un-twisted phone cable, to a CAT5E twisted pair cable, that is just long enough to go between router and socket (with a single twisted pair carrying the signal).
Why bodge when the proper cable is available https://www.amazon.co.uk/rhinocables%C2%AE-Premium-Internet-Broadband-Telephone-White/dp/B01MZF9RAN/...
Sparxoo
Not sure i'd call it a bodge, these cables are commercially available too. The faceplate we have accommodates an RJ45 jack, and there's an RJ11/RJ12 on the other end, with the central pair carrying the signal.
Fixes: 480
@Sparxoo
The reason I called it a bodge is that you said that you were using CAT5E cable. As far as I am aware CAT 5E requires 4 twisted pairs, so to connect the RJ11/12 (or both) end(s) you need to cut off the unwanted cores.
I suspect that the commercially available versions use 2 twisted pair cable.
I was not aware that there were faceplates around with an RJ45 unfiltered output.
Sparxoo
I believe we have an NTE5C variant, installed by OR in 2020/2021.
The flat cable provided with the router was twin flat (no pairs), and I think that Amazon cable is too. Truthfully, I think the intermittent fault on ORs side is back, but I'm going to try everything possible to prove it isn't in the house first, such as interference from homeplugs (removed) or AV kit (router and cables moved again, as far away from the AV stuff and power cables as possible, although cable limitations mean it's still close).
adamwalker
Fixes: 223
Hi @Sparxoo can you send me a PM with your username please and I'll have a look into this on our side for you.
 Adam Walker
Sparxoo
Hi Adam, I've sent it to LaurenB on my other post
Thanks Smiley
Sparxoo
Just to keep the information on this post updated:
Staff ran a test on the line, and said it is possibly internal equipment. We have a 1 year old filtered Mk4 faceplate installed by Openreach when we previously had speed issues (that they eventually appeared to fix).
Have moved the router approx 1m away from the TV/AV gear (was previously tried underneath in the TV cabinet, and also behind it). It is now back on the Plusnet supplied modem lead, which unfortunately has to pass behind it still, but I have ordered another, longer, lead which will allow me to get it onto the other side of the room well away from it. It is also now powered from a different socket, but on the same ring.
All the homeplug adapters are unplugged.
I'm going to give it some time, and then if no improvements, I will swap in my Openreach modem just in case the Hub 2 is at fault.
Sparxoo
Staff have pushed through a DLM reset request for us. Unsure whether it's been processed or not yet, but the router disconnected a few times this morning of its own accord and synced back at a higher speed, download speed is much better (and actually above our minimum guaranteed now).
Lets see how the next few days pan out.
11:55:49, 02 Oct.
WAN connection WAN2_INTERNET_PTM connected
11:55:30, 02 Oct.
DSL Link Up: Down Rate=43412kbps, Up Rate=3576kbps; SNR Margin Down=6.1dB, Up=6.4dB
11:55:22, 02 Oct.
WAN Auto-sensing detected port DSL WAN
11:54:58, 02 Oct.
WAN Sensing Auto sensing Complete, interface selected
11:54:58, 02 Oct.
WAN Sensing Auto sensing Running
11:54:58, 02 Oct.
WAN connection WAN2_INTERNET_PTM disconnected.[ERROR_NO_CARRIER]
10:24:32, 02 Oct.
10:24:13, 02 Oct.
DSL Link Up: Down Rate=45665kbps, Up Rate=5604kbps; SNR Margin Down=6.3dB, Up=6.3dB
10:24:05, 02 Oct.
10:23:42, 02 Oct.
10:23:41, 02 Oct.
10:23:41, 02 Oct.
09:26:37, 02 Oct.
09:26:18, 02 Oct.
DSL Link Up: Down Rate=44985kbps, Up Rate=4644kbps; SNR Margin Down=6.2dB, Up=6.4dB
09:26:10, 02 Oct.
09:25:46, 02 Oct.
09:25:46, 02 Oct.
09:25:46, 02 Oct.
Product code:Plusnet Hub Two
Firmware version:v0.06.00.12134-PN
Firmware updated:17-May-2022
Board version:R01
GUI version:1.6 19_10_2021
DSL uptime:0 Days 4 Hrs 38 Mins
Data rate:3.576 Mbps / 43.412 Mbps
Maximum data rate:3.313 Mbps / 40.959 Mbps
Noise margin:1.8 / 5.4
Line attenuation:9.0 / 18.2
Signal attenuation:7.4 / 22.4
VLAN id:101
