FTTC Problem
tetrastar
FTTC Problem
Hi I'm having issues with my connection, i have never had a plusnet router as always  used others, i'm a pretty savvy user but this is driving me mad really sluggish connections and takes ages to load pages etc. getting the following on my router constantly- can anyone help? i think it could be a problem with the fibre modem? Thanks
9 REPLIES 9
Fixes: 387
Re: FTTC Problem
@tetrastar Welcome to the forums. Which router are you using, and what data can it provide? Just as a start, can you post the output of BT Broadband , obscuring your phone number, please
tetrastar
Re: FTTC Problem
Hi, I'm using a dream machine, not sure if you saw my attached pic? i've attached bt output thanks
Fixes: 387
Re: FTTC Problem
Yes, saw the picture, but it gave no indication of what your modem/router was. The BTW output indicates there is no real problem - you are getting close to max possible speeds to your master socket.
Unfortunately, I have no idea of the dream machines reporting abilities, but it appears you are losing the DSL connection.
Do you by any chance have an up-to-date (in terms of firmware) Plusnet Hub? The output from that, or a similar modem/router, would be more helpful.
tetrastar
Re: FTTC Problem
Hi John,
No i've never had a router from plusnet, i've never been supplied with one from when i first joined years ago.
Sam
Fixes: 387
Re: FTTC Problem
OK Sam. Does the dream machine have  anything like the picture below?
tetrastar
Re: FTTC Problem
Unfortunately no not really, it offers lots of info but nothing i can follow up, can get internet setup page
Fixes: 387
Re: FTTC Problem
Not a great deal of help 🙂
What does 'System' give you?
Re: FTTC Problem
@tetrastar
What modem are you using and does it provide broadband connection details?
This is the information @jab1  is requesting.
Dan
adamwalker
Fixes: 223
Re: FTTC Problem
Hi @tetrastar, please feel free to drop me a private message with your username and I'll take a look into this for you.
 Adam Walker
