Siting my router under the stairs
- Siting my router under the stairs
31-10-2016 1:04 PM
We're getting about half our wireless devices connecting fine, the rest don't connect. In the interests of concealing the cabling, I had the BT engineer install the fibre box in the cupboard under the stairs, and I have connected our 2704n router to that. I read somewhere that under the stairs is a bad place to locate your router; is this the case? And how about the fibre box?
Thanks for your help. Ben
Re: Siting my router under the stairs
31-10-2016 1:51 PM - edited 31-10-2016 1:53 PM
If you want to use wireless, you will place your router in a central location unobstructed by walls, stairs etc.
Ideally it should be placed fairly high on the wall.
You should put the BT connection within a few yards of the router.
Have you tried sitting near the router with those devices that don't connect wirelessly?
31-10-2016 9:06 PM
Thank you. Do you happen to know how I can get someone from BT out to re-site the fibre box?
01-11-2016 1:41 AM
It would cost you an arm and a leg.
Run a telephone style cable to your router, this should be reasonably short, if possible.
Other possibilities exist if the distance is large.
