Signing out on Hub Manager
- Signing out on Hub Manager
04-09-2021 2:28 PM
Troubleshooting says I need to sign in with my own account....but I can't see an option anywhere to sign out and sign in with different account on hub manager. Is there a way to do that? Thanks
Re: Signing out on Hub Manager
04-09-2021 2:30 PM
@mwarren91 Welcome to the forums. Try this:-
1. Connect a device onto the router's WiFi or plug a laptop/PC into the router using an ethernet cable
2. Go to the router's homepage at http://192.168.1.254
3. Click on the Advanced Settings tab
4. Type in the admin password found from the back of the router and click the OK button
5. Click on the Continue to Advanced Settings button then the Broadband tab
6. If there's a Disconnect button, click that
7. Change the username to the broadband username in the format of [email protected] If you can't remember this I'd check for any emails PLUSNETsent you as they'd add the username to the top of the email.
8. Type in the account password, this can be reset here: https://www.plus.net/forgotpassword/ if needed.
9. Hit the Connect button.
