Should I Upgrade to Your Way?
- Re: Should I Upgrade to Your Way?
01-01-2008 3:54 PM
I've been using plusnet broadband since 2002 on the Premier Option 1 package. I've never had any issues with the capacity of this package, but this month exceeded 10GB peak time download and received an email alerting me to this fact - even though the peak time acceptable use limit is 20GB on my package (I think). The email also suggested I upgrade to the Broadband Your Way product. I've looked at the Broadband Your Way package options and I can't see any benefit in me upgrading - other than maybe saving a couple of quid by going for the 20GB per month option.
Can anybody explain how Your Way is better than Premier Option 1 please?
Cheers,
David
01-01-2008 3:58 PM
01-01-2008 4:22 PM
im also on prem op 1 and had a look at the new options but find the peak time 4 pm to midnight much better than BBYW 8 am to midnight. i do any large downloads eg p2p ect, after 12 am so they dont eat into my peak allowance.
i find it works for me and i have two teenages using the connection plus x box live
"if it aint broke, dont fix it"
01-01-2008 10:02 PM
I thought I must have missed something since the offer was described as an "upgrade", losing 50% of the un-metered off peak hours and only saving 10% on the cost doesn't sound like much of an upgrade to me.
01-01-2008 10:07 PM
02-01-2008 10:31 AM
It is entirely possible (and looking at your usage, probable) that changing to Broadband Your Way may not suit you. We are not forcing you to change and if your current is serviing you fine then there should be no need to change.
02-01-2008 11:10 AM
I thought the loss of 8 hours off peak unmetered time might prove an obstacle but it hasn't.
I know it's only a saving of £2 per month but you won't get throttled at 13GB or whatever the figure is like you do on Option 1.
02-01-2008 12:52 PM
And me neither ;D......
Quote from: BatCat Hmmm....
Quite happy where i am....on Premier Option 1 ......and have no intention changing!!
(or leaving Plusnet)
03-01-2008 11:16 PM
Always worth reviewing the product vs usage periodically though.
Cheers,
David
04-01-2008 10:00 AM
