Service down 13/07/2013 @ 17:10pm
- Service down 13/07/2013 @ 17:10pm
13-07-2013 5:23 PM
Doesn't look like a BT issue, line tests are fine,
Lee
Re: Service down 13/07/2013 @ 17:10pm
13-07-2013 5:45 PM
My internet was only own a few minutes, then back up and still on, interference and all.
gtowen
13-07-2013 6:04 PM
Line state: Connected
Connection time: 15 days, 20:33:05
13-07-2013 6:10 PM
Changed router, rj11 cable, removed faceplate etc. looks like im going to have to sit tight..
13-07-2013 6:19 PM
13-07-2013 6:59 PM
I'll edit the bookmark to point at the PlusNet portal when they add a similar page...
13-07-2013 7:08 PM
pcl-ag02 goint to try a hop again
13-07-2013 7:27 PM
Quote from: Oldjim does this give any information http://status.zen.co.uk/broadband/
Very useful, thanks
Unfortunately my area isn't on that list
13-07-2013 7:28 PM
13-07-2013 8:09 PM
Router confirming concentrator not reachable...
Thanks for all the info everyone.
13-07-2013 10:43 PM
Plusnet said they cannot see a fault and nothing has been reported apart from a few calls due to slow Internet.
My phone and iPad speed has literally halved at best, laptop seems semi ok for a while.
Do we just sit tight and hope? I guess it is not just me having the problem then. Literally from fast speed to almost nothing download but router stating it is connected yet cannot view a web page.
Regards
Craig
15-07-2013 1:57 PM
It still seems that you're not connected, have you tried to reconnect? If you have and it's still not working I'd suggest running through our faults wizard at http://faults.plus.net
@hypnoboy
I can see that we have pushed this fault back for further investigation today and our faults team will update you as soon as they can.
