Samknow white box
- Re: Samknow white box
21-04-2013 5:42 PM
Quote from: shalom2010 http://www.samknows.com/broadband/uploads/foundationmodule/SQ303-001-EN-Whitebox-Briefing-Fixed-D02.pdf
This doc implies TP-Link routers WR741 (100Mbps) and WR1043 (Gb and N300), though
Quote from: apjashley1 mine was a WDR3600
which is Gb and dual band N600 with IPv6 capability
![Cheesy Cheesy](/html/@69488338D0B3891CC5F8AEAEEB30C648/images/emoticons/cheesy.gif)
21-04-2013 5:43 PM
I got supplied the tp-link TL-WR741ND which is 100Mbit
21-04-2013 5:53 PM
21-04-2013 7:29 PM
PeeGee would your internal transfers still be at gigabit through the WR1043? Or does every 'bit' need to pass through the router and Whitebox?
22-04-2013 1:11 AM
So in theory, this renders the Wifi on your router useless if you wanted to use the Whitebox properly.
22-04-2013 6:08 AM
22-04-2013 10:42 AM
I just need to hope they are sending me the better TP-Link box with Gigabit WAN and LAN.
26-04-2013 9:09 AM
[me=Finguz]prays MI5 aren't watching ::)[/me]
Edit: I'll make sure to check there are no black choppers hovering overhead before I power it up.... I have noticed several people with sunglasses on
![Lips_are_sealed Lips_are_sealed](/html/@F9AC2D8C2C4C8B1A90221A46DDE6168E/images/emoticons/lipsrsealed.gif)
26-04-2013 10:13 AM
Quote from: apjashley1 PeeGee would your internal transfers still be at gigabit through the WR1043? Or does every 'bit' need to pass through the router and Whitebox?
Sorry for the delay - a gigabit whitebox (I've just received the WDR3600v1.2 like Finguz
![Wink Wink](/html/@ED8EAB3707DE077FFF94EEBAB958E3C6/images/emoticons/wink.gif)
![](/skins/images/92574217454FFC7479DE340AFA292BEC/responsive_peak/images/icon_anonymous_message.png)
26-04-2013 10:22 AM
![Smiley Smiley](/html/@39650D28FE4EA73A5BA77CFD0A477003/images/emoticons/smiley.gif)
TP-LINK TL-WDR3600v1.2 "N600 Wireless Dual Band Gigabit Router"
I need to find some screws, so that I can mount it on the wall before switching it on !
![Roll_eyes Roll_eyes](/html/@BA2C29EA5D62B3049244C6EF0F36F4A9/images/emoticons/rolleyes.gif)
26-04-2013 10:40 AM
Just got mine as (I thought it's supposed to be a white box ?)
Mine is the same N600 Wireless Dual Band Gigabit Router. How do you know it's a TL-WDR3600v1.2
![Huh Huh](/html/@E2297E1574AC8AB2FE5882A8865382BF/images/emoticons/huh.gif)
Connected quickly & speed test & pings seem normal. Just got to wait for the email now for login info.
26-04-2013 11:38 AM
26-04-2013 11:43 AM
Ah, found it
26-04-2013 1:43 PM
26-04-2013 1:50 PM
![Sad Sad](/html/@5863905B9AC6EE4F2B28C1A2965ABC0C/images/emoticons/sad.gif)
