SORRY Netgear n300 dgn2200 problem connecting there must be a solution PLEASE
- Re: SORRY Netgear n300 dgn2200 problem connecting ...
- « Previous
- 1
- 2
- Next »
Re: SORRY Netgear n300 dgn2200 problem connecting there must be a solution PLEASE
29-06-2011 8:33 AM
I've just updated your fault ticket with the next stage of my plan.
Jojo
29-06-2011 9:58 AM
Connection Status
Connection Time 00:00:00
Connecting to server Off
Negotiation --
Authentication --
Getting IP address --
Getting Network Mask --
Router Status
Hardware Version DGN2200
Firmware Version V1.0.0.36_7.0.36
GUI Language Version V1.0.0.25
Internet Port
MAC Address C4:3D:C7:46:8F:82
IP Address 0.0.0.0
Network Type PPPoA
IP Subnet Mask 0.0.0.0
Gateway IP Address 0.0.0.0
Domain Name Server 212.159.6.9
212.159.6.10
LAN Port
MAC Address C4:3D:C7:46:8F:81
IP Address 192.168.0.1
DHCP On
IP Subnet Mask 255.255.255.0
Modem
ADSL Firmware Version A2pB025c1.d21j2
Modem Status connected
DownStream Connection Speed 3616 kbps
UpStream Connection Speed 448 kbps
VPI 0
VCI 38
SHOW STATISTICS PAGE
System Up Time 2 days 20:01:32
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN Link Down 0 0 0 0 0 00:00:00
LAN1
LAN2
LAN3
LAN4
WLAN
ADSL Link Downstream Upstream
Connection Speed 3616 kbps 448 kbps
Line Attenuation 57.0 db 27.0 db
Noise Margin 12.8 db 21.0 db
29-06-2011 10:40 AM
29-06-2011 12:05 PM
10-07-2012 6:42 PM
Btw I have the same firmware.
11-07-2012 1:04 PM
If I have read this right, you now have 1, BT Voyager router, and 2. Netgear routers. Take one or two spare routers over to your friends house who is on O2, and ask them to test it for a few days to see if it's disconnecting on their connection. It's very unusual that 3 routers will all have the same problem.
If the routers are fine at your friends house and dont disconnect, it proves the problem is either in your house, or on the BT line.
Whilst your looking at your router stats next time, are the figures it shows you refreshed every few seconds as I'd like to know what the downstream noise margin is doing. On one of your previous posts, you say it's on 12.8db which is just a snap shot at that momment in time. If you press refresh button on you web browser every few seconds, is that figure varying a lot?
11-07-2012 4:30 PM
Plusnet had identified a bug in the Netgear firmware if you read the link I posted. There are several similar recent threads around this forum.
Whether the firmware issue has been resolved I don't know, I haven't researched it, but setting the DNS in the modem/router solves the issue in most cases.
11-07-2012 4:44 PM
No research needed, the BT VOYAGER ROUTER does not run any netgear firmware.
jim:quote
11-07-2012 4:48 PM
11-07-2012 5:10 PM
mkc66's problem does not read as a netgear problem, as two different routers having the exact same fault is highly unlikely.
11-07-2012 5:19 PM
Wouldnt mind a faster upload speed if possible
13-07-2012 10:59 PM
- « Previous
- 1
- 2
- Next »
