Router disconects ....time for a replacement router???
- Re: Router disconects
05-10-2011 8:43 AM
05-10-2011 11:30 AM
Our logs are only showing one disconnection since things started yesterday? If you're using a wireless connection between your PC and the router it might be worth trying with an ethernet cable as it may well be the wireless connection dropping out. If it's not, and it still hasn't settled by the time the 10 day training period is up then run through the troubleshooter at http://faults.plus.net
05-10-2011 12:25 PM
05-10-2011 1:14 PM
I'd say you may have to troubleshoot the adapters. Firstly it's worth checking whether it happens when connected just with the ethernet cable directly.
Jojo
05-10-2011 3:11 PM
05-10-2011 6:13 PM
05-10-2011 6:27 PM
Just put in your supplied PN username @plusdsl.net and corresponding password into the hub and see if it will connect. Also switch off Openzone function in the Home Hub.
I know a BT Home Hub v2 (type A) used to work on PlusNet the last time I tried a few years ago. The firmware has probably been updated, so I can't confirm whether or not BT still allow their hubs to be used on PlusNet. Worth a try though.
05-10-2011 9:06 PM
dick:quote
05-10-2011 11:32 PM
So do I have a similar problem to what is being described in this thread....? http://community.plus.net/forum/index.php/topic,92497.0.html
Re: Router disconects ....time for a replacement router???
06-10-2011 7:17 AM
06-10-2011 9:37 AM
I doubt a replacement router will just cure the issue. There's a couple of things you could try. Try setting the router's wireless encryption to WPA instead of WPA2. There's instructions on how to access the wireless settings here. Other wireless troubleshooting tips can be found here. It may also be that the wireless channel has other things being broadcast on it. You can use something like inSSIDer to find out the clearest channel to use.
Jojo
06-10-2011 10:41 AM
06-10-2011 10:42 AM
07-10-2011 10:23 AM
Thanks again, hate to imagine the hassle I would have had with BT Mumbai trying to sort this out.
dick:quote
