Router connected but no internet
adamwalker
Fixes: 223
Re: Router connected but no internet
Hi @SpicyPineapple from reading your posts I agree with jab1 that it does sound like a fault with the router. I've sent out a replacement for you which should reach you within the next 3 to 5 working days.
Please let us know how things go once that's reached you.
 Adam Walker
SpicyPineapple
Thanks @adamwalker I got the confirmation text this morning and was very pleased to see it 😊
Thanks so much @jab1  for all your help and detective work, I really appreciate it. Also to the others who posted to help, huge thanks from me.
Longliner
All Star
Fixes: 8
Away for a few days and hope your router has turned up by now, but suggest you take a quick look at auction sites and see if you can pick up a BT HH6 for £10-£20. Plenty of advice on setup etc on this site. Much better than Hub One which I keep as a spare. Good luck!
Mike
