Router Stats
- Re: Router Stats
Router Stats
21-11-2012 9:40 AM
Morning everyone, do these Stats look OK.
Error Seconds (Local/Remote): 65,540 / 0
FEC Errors (Up/Down): 469,891 / 22,727,603
CRC Errors (Up/Down): 7,710 / 2,486
HEC Errors (Up/Down): NA / 73,553
Message 1 of 9
(1,289 Views)
8 REPLIES 8
Re: Router Stats
21-11-2012 10:07 AM
How long is that over? If those are the counts accumulated in the last year they are excellent; if they are from the last minute they are dire!
The error seconds look suspiciously close to -1 which makes me think we can't rely on that to judge the period.
Message 2 of 9
(531 Views)
Re: Router Stats
21-11-2012 10:08 AM
It's not possible to tell if there's an issue or not from router stats alone really. Are you experiencing any other noticeable problems such as slow speeds? I've checked to see how the connection is performing in terms of stability and can see you've been online for 3 days now so that doesn't seem to be an issue.
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13534924479643.png" />
Message 3 of 9
(531 Views)
Re: Router Stats
21-11-2012 10:17 AM
sorry to mention it yeah its been 3 days i reset the router back to factory settings and i had 2 days of slow speeds after but now its back to normal.
Message 4 of 9
(531 Views)
Re: Router Stats
21-11-2012 10:20 AM
You would be much better off posting your sync rate(s), noise margin and attenuation for comment.
Message 5 of 9
(531 Views)
Re: Router Stats
21-11-2012 10:23 AM
They might be a little bit high, but if you are not having any problems not enough to worry about. Adam's graph is more significant and looks good.
Next time you have to do a disconnect/connect and after your next reboot check to see if the counts reset so you can be sure of the period they are over.
Message 6 of 9
(531 Views)
Re: Router Stats
21-11-2012 10:27 AM
Quote from: ReedRichards You would be much better off posting your sync rate(s), noise margin and attenuation for comment.
here my stats.
Message 7 of 9
(531 Views)
Re: Router Stats
21-11-2012 11:24 AM
I'm slightly bothered by the increase in HEC errors from your previous figures (these are hard errors requiring a retransmit that interleaving could not correct).
We normally say resync in daylight hours to get the best speed, but it looks like your target noise margin is 3db so, presuming at times you see it below 3, I'd be tempted to watch to see when it's at it's lowest and resync then. The sync speed would drop a bit but with a higher margin you'd see fewer errors.
Message 8 of 9
(531 Views)
Re: Router Stats
22-11-2012 10:18 AM
can someone help me, today i have check my router (stats) and i can see there is some more errors (more errors attachment) I'm not sure if its because the internet went offline ???. thanks
Message 9 of 9
(531 Views)
