Repeadtedly being disconnected remotely today
- Repeadtedly being disconnected remotely today
29-02-2012 3:30 PM
Started 13:00 approx
5th time so far.
Can immediately re-connect from modem management.
Line stats:
SN looks a bit squiffy!
Any tips?
5th time so far.
Line stats:
Link Information
Uptime: 0 days, 0:01:14
DSL Type: G.992.5 annex A
Maximum Bandwidth (Up/Down) [kbps/kbps]: 1,104 / 9,972
Bandwidth (Up/Down) [kbps/kbps]: 1,011 / 9,944
Data Transferred (Sent/Received) [kB/kB]: 33.00 / 117.00
Output Power (Up/Down) [dBm]: 12.5 / 20.0
Line Attenuation (Up/Down) [dB]: 18.5 / 33.5
SN Margin (Up/Down) [dB]: 8.0 / 9.5
Loss of Signal (Local/Remote): 131,072 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 131,072 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 159 / 1
HEC Errors (Up/Down): 294 / 1
Any tips?
Message 1 of 2
(613 Views)
1 REPLY 1
Re: Repeadtedly being disconnected remotely today
29-02-2012 3:58 PM
It definitely does look like the line's dropping connection. I think the best bet would be to do the usual dropping connection diagnostics, most importantly testing the connection with the router in the master socket and everything else unplugged from the line to see if the drops still occur. If not, you know it's something that's plugged into the line; if so then raise us a fault and we'll get investigating for you.
Message 2 of 2
(285 Views)
