Renewing Contract Online?
joecool
Hi present contract runs out next mth & can't renew online, when I try it just says "Something Went Wrong try later" It would just be convenient at the moment.
Appreciate any help
Thx
5 REPLIES 5
Fixes: 110
Re: Renewing Contract Online?
@joecool
Is Full Fibre available to you. Check  - https://www.broadbandchecker.btwholesale.com/#/ADSL
You're looking for WBC FTTP in the left hand column.
If it is then PlusNet are not currently showing upgrade options as they sort out their website. Full Fibre isn't available to new customers. You need to phone in to find out your choices.
Be aware that if it's available and you order it, you lose your phone line and NUMBER.
Fixes: 472
@joecool
The fact that you have posted on the full fibre board might be causing confusion. If you are referring to the standard FTTC fibre or fibre extra service then can you please advise and I will move your post to the correct board..
Either way, your best bet is to ring the Customer Options Team on 0800 013 2632. This number is normally answered quite quickly
joecool
Hi thx for comments, present contract with Plusnet is unlimited fibre. I'll just ring.
Thx
RobPN
Fixes: 14
@joecool
I think @Baldrick1 was trying to establish whether you're presently on real fibre (FTTP) or pseudo fibre (FTTC).
Fixes: 472
Moderators Note
This topic has been moved from Full Fibre
