Internet disconnecting and now speed halved
FIXED- Subscribe to RSS Feed
- Internet disconnecting and now speed halved
24-06-2022 10:11 AM
Hi, my internet has been disconnecting each evening this week, and today we struggled to have two Zoom calls going at once, so I checked the speed - the line is down to 36mb when it has been around 60 since we moved here a year ago. My guaranteed speed is showing as 32 mbps in my plusnet account, but I'm also certain this used to be higher.
Has something happened to my line to halve the speed like this, and is there anything I can do to get it back to how it was? Struggling to work with the current speed (my wife and I both working from home as is the way these days!).
Any help appreciated, thanks!
Fixed! Go to the fix.
Re: Internet disconnecting and now speed halved
25-06-2022 10:09 AM
@samdraper Welcome to the forums. Staff support over weekends is patchy, so maybe if you follow the instructions below, other Community members may be able to suggest a course of action:
For Community members to be able to help, information from these two sites, as screenshots:-
BT Broadband(obscuring your phone number) and BTW Performance Tester - Over a wired (ethernet) connection if at all possible, please report the 'ADDITIONAL DIAGNOSTICS', and sight of the broadband connection status from your Hub would be a good starting point.
For the Hub One -
For the Hub Two -
If phone test is OK then take the front off your telephone master socket, you may need to remove two screws. In behind you will find the test socket. Plug a filter in here and connect that to your hub. If it’s still dropping out then report a fault at https://faults.plus.net.
25-06-2022 11:05 AM - edited 25-06-2022 11:06 AM
Hi John, thanks for your detailed message. I've attached the results of the BT tests, does anything look amiss? I don't use my Plusnet hub but will try and find it out from wherever I've chucked it in the loft! I also did the quiet line test and the line seemed fine.
25-06-2022 11:31 AM
@samdraper Looking at the 'Advanced Diagnostics' and the BB checker, am I correct in thinking you are on the 'Fibre Extra' - 80/20 product? If so, your profile looks horribly wrong as it seems to be limited to the 40/10 speed on download, but on the 80/20 for upload.
Which modem/router do you use? If you can get similar detail as the picture below from it, no need to use the Hub - H1 or H2?
25-06-2022 11:53 AM
That's correct, I am on Fibre Extra. I use an Archer VR400, I've attached the similar screen from my router. Thanks
25-06-2022 12:01 PM
Sam, from that last screenshot, I am fairly convinced you have a BT network problem - your DSL uptime suggests you have been having disconnections which should not be happening.
I suggest you report a broadband problem, using the 'report by text' option on this screen:- https://www.plus.net/help/report-a-problem/broadband/
27-06-2022 2:11 PM
30-06-2022 9:33 AM
Hi @adamwalker I PMd my plusnet username yesterday, any help appreciated! I did try the text troubleshooter thing @jab1 recommended at the weekend - it didn't fix anything and I didn't get a call after choosing the 'adviser' option.
01-07-2022 1:41 PM
Hi Sam, I'm really sorry for the delay as we've been fairly busy recently.
I've tested your line and the tests are showing your router's getting 38mbps and seems to have been stable over the last 7 days. Our suppliers estimate you should be able to get between 55mbps to 72mbps though.
From what I can see you've placed an order online to upgrade to full fibre (FTTP) at ~500mbps about half an hour ago, which would be an incredible boost in speed and hopefully a more reliable connection as well. ![]()
As this won't be installed for at least another couple of weeks, do you want us to investigate the fault still? If so we'd need to arrange an engineer visit, so let me know when you'll be available and I'll book the appointment.
The engineers are available weekday timeslots (and occasionally Saturday's) of 8am to 1pm, or 1pm to 6pm.
01-07-2022 3:04 PM
Thanks @Gandalf. Yes, I have just placed the FTTP order, I can't wait! I'll muddle through with the reduced speed until then, don't want to risk being disconnected altogether for another visit- I've already had to negotiate the FTTP upgrade with my wife, don't want to push it too far 😅
Thanks for all your help in trying to resolve this anyway, cheers!
01-07-2022 3:09 PM
Haha awesome. No problem and sounds like a plan!
Let me know how the FTTP order goes. Cheers
