Really bad storm
- Re: Really bad storm
21-07-2014 9:01 AM
I'm sorry to hear that the weather has caused a problem with your router. The warranty on your router ended in late January this year unfortunately so it's not quite as straight forward as replacing it for the now faulty equipment.
You'll need to give us a call on 0800 432 0200 and speak to our Support Team and they will be able to get this issue sorted out for you.
21-07-2014 9:22 AM
21-07-2014 9:43 AM
21-07-2014 11:09 AM
Typical switch mode PSUs of this type these days are generally rated 100-240V ~50-60Hz, 12V DC 1.0A. Make sure it has the 2.5x5.5mm output plug for the TG582n.
The exact Thomson model that I have is Model: ADS0126A-X120100 Part No: DSL36879820 which you may or may not be lucky to find on the Internet, I don't know if it's available direct from Thomson - but it might be cheaper to pick up a second hand 582n complete with it's power unit.
PLEASE BE WARY OF CHEAP FOREIGN IMPORTED POWER UNITS WHICH CAN BE UNSAFE AND CAN BE A FIRE HAZARD and buy power units from a recognised reputable UK supplier.
Edit: add details of the DC output plug.
21-07-2014 11:23 AM
21-07-2014 11:25 AM
21-07-2014 11:30 AM
My 582n adapter appears to have a 5.5mm outer plug with a 2.5mm inner plug although it could be a 2.1mm. 12v @ 1A as stated above and almost certainly regulated.
If I was to grab one as a replacement I'd go for this :
http://cpc.farnell.com/pro-power/nk120p100puk-g/ac-dc-power-supply-12v-1a-2-5mm/dp/PW02685?in_merch=...
£6.18 delivered and from a fairly reputable company.
It *could* be a 2.1mm inner plug by my digital calipers won't go into the socket to get a better measurement and a 5.5x2.5mm should fit.
21-07-2014 11:35 AM
She's with BT and she's just brought her BT Hub in to see if I had a replacement as all BT would do, upon phoning up, was to sell her a new complete router.
She's a bit skint, but luckily I had a spare BT Hub3 which I swapped for a donation to my charity box and all is well for her. Might be worth a try yourself, pop down to your local independant computer shop and see if they can find something for you. If they're anything like my workshop, there's bound to be a boxful of various PSUs somewhere.
21-07-2014 11:37 AM
And obviously buy power units from a recognised reputable UK supplier. The one linked above is an example.
21-07-2014 11:40 AM
@DieselSheff - if you can hang on till later this afternoon I can try a PSU with a 5mm/2.5mm plug and make sure it is a snug fit.
21-07-2014 12:08 PM
@DieselSheff please remember it's not Plusnet's fault that the lightning has zapped your unit - they aren't obliged to do anything, I'm sure they would have done if they were able to but as I implied before, that would be unlikely.
22-07-2014 2:47 PM
22-07-2014 3:02 PM
Whilst I appreciate the inconvenience of having your router fried, I think you're being unreasonably rude and critical of PN.
You had a lightning strike and it affected your router just like it could have blown your telly or your fridge. It happens.
I'm sure they'll do their best to help you out but you need to know very clearly that they are under no obligation to do so.
Even if the router was under warranty, the manufacturers would be well within their rights to claim that what happened was not a fault due to a production error but the unit being subjected to conditions outside its normal operating parameters.
Whilst I appreciate that you "post like you talk", I think claiming to be disgusted with customer service is unreasonable.
Good luck.
André
22-07-2014 3:14 PM
Personally, I'd either get an universal power supply with swappable ends (this kind of thing: http://www.amazon.co.uk/Masterplug-MVA1200-1200mA-Multi-Voltage-Adaptor/dp/B0083S19YW/ref=sr_1_5?ie=... or spend a little extra and buy a better router.
I do find it odd (but far from impossible) that you only lost the power supply in the storm. Usually lightning strikes knock out either the router itself totally, the network switch or the ADSL modem parts in my experience.
22-07-2014 5:25 PM
The PSU linked in reply #21 at CPC Farnell should be perfect for the job.
@DieselSheff
If the 2A supply that you have is 12V DC, then it should be perfectly OK.
Bear in mind, that although you said in your OP that it worked OK with the laptop charger, until you've tried it for an extended period with a proper supply, you can't be certain it wasn't damaged as well. The 2A supply certainly won't harm it.
