setting up tg582 do not allow new stations
nevillefreedman
I have an new tablet which I can connect wirelessly but when I change the setting to "Do not allow new stations" in the access panel of the wireless config screen the tablet disconnects from the router.
I have set up a tablet previously which intitialy did the same and now works with that setting but I cannot remember how I overcame the problem.
Can anybody help please?
5 REPLIES 5
Oldjim
Resting Legend
Fixes: 63
Re: setting up tg582 do not allow new stations
nevillefreedman
Thanks, I will give it a try. Will I be able to block somebody that could previously connect but should no longer have access.
Fixes: 160
If that is what you want to do, then change the WiFi password.
Oldjim
Resting Legend
Fixes: 63
If they are no longer registered - you removed them - then according to the link that should be the case
nevillefreedman
Townman : because that would mean changing the password on a number of machines including some visitors.
Stopping them from reregistering once deleted, would be preferable to changing the password.
