Re: Lower sync than expected
youngsyp
Watching this thread with interest as I had a similar situation when I was first connected.
In my case, as Plusnet had failed to send the router out in time for my switchover, I was ADSLess but still had my Be supplied TG585v7 connected. That sync'd at 3500Kb/s ish. When I got the TG585v8 from Plusnet a week or so later, the best I've ever sync'd at is 3104 Kb/s (currently). My line has supported 4084 Kb/s for 3 years prior to that...
Paul
youngsyp
Quote from: Mav
Is it worth trying with interleaving off?
That will improve your sync and throughput however, were you on fastpath previously, when you hit you faster sync?
If not, it's not a fair comparison and will brush any potential issue under the carpet...
Paul
ETA: Without meaning to point out the obvious.  Embarrassed
Mav
Fixes: 515
Mmmmmmm, you've just reminded me (not sure how, though ;)) that I still have a NetGear router somewhere to try. I'll look for that - it may be at my old address which I won't be going to for a few days.
AFAIK I've never been on fastpath.
Forum Moderator and Customer
Mav
Fixes: 515
@ Jojo
I may be stabbing myself in the foot here but I have been undercharged this month. I'm on a Market 1 exchange but being charged per Market 3. I'd be the first to complain if I was overcharged, so...
Edit: Thinking about it, perhaps I should have started a new thread for the undercharge. Mods....?
jojopillo
Hi Mav,
[quote=Mr. Honesty]I may be stabbing myself in the foot here but I have been undercharged this month. I'm on a Market 1 exchange but being charged per Market 3
Thanks for the honesty there but if you move to a different market area from market 3 you still keep the price until the end of your contract.
Jojo Smiley
Mav
Fixes: 515
I never knew that. Thanks Jojo
Mav
Fixes: 515
I seem to have had many disconnects over the past few days and around midnight last night re-synced at just over 4100, so I now have a profile of 3500 Sad
I finally got hold of my Netgear DG834G V4 (V4.01.40 firmware). It is plugged directly into the test socket and immediately synced at 5376. S/N margin is currently 0dB and Att is 46dB. The S/N seems to fluctuate between
4 & 0 (Routerstat graphs below).
Not sure how stable this line is and assume the vertical bars in the Sync Speed graph means that disconnections occured at those times.
A couple of other questions still unanswered:
Would I get faster throughput if I synced at 5588 rather than 5120 even though the profile would remain the same at 4500?
Is it worth trying without interleaving to see if I can achieve the 5568 I originally got?
@Jojo
This page still shows my old number. I understand you say it doesn't affect my connection but I don't understand why it has never been updated.
Also, why does it say :
Estimated line speed:
   4 - Checked on 2010-11-07 22:48:06
This was the day before I moved and it the internet was still on at my old address at that time.
spraxyt
Resting Legend
Fixes: 75
I think the vertical bars in the sync speed graph are most likely to be missed data collection points (router busy with other tasks and slow to respond to routerstats) rather than loss of sync. Generally if sync is lost the sync speed changes on reconnection, and the dips are V shaped since it takes a finite time to reconnect.
The noise margin is rather lively and in my opinion uncomfortably low for maxADSL. The router is doing well to maintain connection. Are there a large number of errors (Routerstats will show that information on the status pages).
I don't think there is significant advantage in being synced at the top end of an IP Profile range rather than towards the bottom (5120 - 5664kbps for 4500kbps IP Profile) .
David
jelv
Fixes: 10
If there are a large number of errors you probably don't want interleaving off. The BT system would be very likely to put up your target noise margin which would give you a lower sync.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Oldjim
Resting Legend
Fixes: 63
Try increasing the default noise margin using DMT
jojopillo
HI Mav,
Interesting question. I would imagine it may help to get you closer to the 4500. It does seem logical.
As for the number and the exchange check, they are anomalies and don't affect your service, so when I get a chance I will try to look further into that for you.
Jojo Smiley
WWWombat
Quote from: spraxyt
In addition, Routerstats tends to colour the line differently if the drop to zero is because of a missed reading, rather than a true reading of zero. Unfortunately, the line is then coloured normally again when it returns from zero back up to the next (normal) reading - and because of the "V" shape, the lowest segment of the "going up" line can overwrite the lowest segment of the "dropping down" line. It can be hard to tell sometimes.
IIRC the usual colour of this "failed reading" is red, and I see your standard colour is kind-of-red, making it hard to distinguish. Perhaps if you reconfigure the graph to show a different colour it will help. As it stands, it looks like 3 of those drops are a slightly different shade.
I agree with the previous post - the noise margin looks uncomfortably low. Logic would suggest it is close to disconnecting, and that if it did so, it would resync at a lower speed and a higher noise margin.
Plusnet Customer
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
198kHz
Fixes: 41
Quote from: Mav
No. DLM is a conservative beast, and 5120 is quite a way above 4500. 5200 - 5300 would be preferable to give a bit of lee-way, of course, but there's no point in pushing for the max unless you can reach the next threshold at 5696.
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice   FRITZ!Box 7530
BT technician (Retired)
Mav
Fixes: 515
Thanks for the replies and advice.
I have changed the colour for the sync speed plot and have added a recent graph.
I can't seem to get the status to show on the Summary page. I have added a jpg and have checked the settings nd can't fathom why I'm not getting the relevant details.
Never changed the SN directly before using DMT. Can I use the tool in RouterStats 6.5C? If so, what two values should I enter?
Thanks again.
Edit: Have downloaded what seems to be the latest version of DMT(9.01), entered the router's IP address (192.168.0.1) and the ID and password but get the message 'Error: can not identify modemtype. DMT version 9.01 for SpeedStream_4100/4200/5100/5200, Teledat_302/430'
Oldjim
Resting Legend
Fixes: 63
Routerstats asks you to put in the default value and the new one you want but AFAIK it just works from the ratio so putting in 6dB and 9dB should increase it by about 3dB
