RPWD Speed Problem
- Re: RPWD Speed Problem
04-04-2012 8:57 AM
04-04-2012 9:12 AM
Can you answer the last question I asked
Quote Can you describe exactly what happens when you lose connection and have to unplug the router to sort it - do any of the lights on the router turn red or is it that the computer loses the connection to the router rather than the router losing the connection to the exchange
04-04-2012 10:19 AM
Quote from: rpwd Thank you very much, Jim. I just uploaded a photo about my connections. The socket is on the wall, so I cannot see if there is a master socket or not.
The short adapter is connected to the wall socket. The gateway is connect to the adapter as shown in the picture.
Would you please help me to figure out what is the problem?
That looks like a modern master with a test socket to me.
If you undo the two screws the bottom half will pull out and you will find a test socket inside.
It also looks as if it may not be seated correctly as the left hand side looks to be stuck out further than the right - it may be that is the cause of your issues.
04-04-2012 10:22 AM
04-04-2012 10:31 AM
The speed will still be the same until I lift the banding. I need you to remove the bottom half of the faceplate and plug the filter inthe socket behind. Once you have done that I can get the speed back again.
Jojo
04-04-2012 10:50 AM
i do not use any phone. just the broadband.
i will try to remove the faceplate and find the test socket this afternoon. Hope there is one test socket there.
04-04-2012 11:21 AM
Quote from: rpwd i do not use any phone.
You need to borrow a telephone (preferably wired not cordless) and check the phone line is working correctly. If there's noise on the phone line that needs reporting to whoever you pay for the phone rental before addressing broadband issues (broadband just won't work correctly on a dodgy phone line).
04-04-2012 11:45 AM
Quote from: rpwd i will try to remove the faceplate and find the test socket this afternoon. Hope there is one test socket there.
Please let me know when you do this
04-04-2012 12:15 PM
Really thanks.
04-04-2012 12:49 PM
just bear in mind that you won't see any difference when you plug into the test socket, but I just want you to leave it in there so I can remove the banding in with the knowledge that if any more issues appear it's more likely to be external. I'd also recommend using a different filer while you're at it.
Jojo
04-04-2012 4:04 PM
thanks for reminding the speed don't change thing, otherwise i will be confused for there is no change happend.
04-04-2012 4:11 PM
04-04-2012 7:42 PM
what can I do now?
04-04-2012 7:56 PM
04-04-2012 8:15 PM
then the router is connected to the filter. there is another socket on the filter for phone, which is empty at this moment.
