REIN trouble (mostly fixed)
- Re: REIN trouble (DLM strangely inactive)
Re: Where's the DLM when you need it?
01-07-2013 5:41 PM
01-07-2013 5:51 PM
01-07-2013 10:22 PM
Well the interference seemed to stop at about 21:50 tonight, just for it to resume about 5 minutes later, then stop again after another few minutes. I think the interference is visible in the DS margin, it's just wasn't a big enough change for me to notice. Changed from 6.0 to 8.1 (that's an average, rather than a minimum that would be reported by default). And the interference is back again at 22:20.
02-07-2013 5:59 AM
02-07-2013 7:22 AM
AR7 DSL Modem Statistics:
[DSL Modem Stats]
US Connection Rate: 708 DS Connection Rate: 3658
DS Line Attenuation: 60.4 DS Margin: 5.9
US Line Attenuation: 36.8 US Margin: 4.6
US Payload : 4416 DS Payload: 4704
US Superframe Cnt : 18337 DS Superframe Cnt: 18337
US Transmit Power : 0 DS Transmit Power: 0
LOS errors: 0 SEF errors: 0
Errored Seconds: 2 Severely Err Secs: 0
Frame mode: 0 Max Frame mode: 0
Trained Path: 1 US Peak Cell Rate: 1669
Trained Mode: 16 Selected Mode: 1
ATUC Vendor Code: 54535443 ATUC Revision: 3
Hybrid Selected: 3 Trellis: 1
Showtime Count: 1 DS Max Attainable Bit Rate: 3804 kbps
BitSwap: 1 US Max Attainable Bit Rate: 1100277 bps
Annex: AnxA psd_mask_qualifier: 0x0000
Power Management Status: L0 DS HLINSC: 0
US ACTPSD: -345 DS ACTPSD: -366
Total init. errors: 0 Total init. timeouts: 0
Showtime init. errors: 0 Showtime init. timeouts: 0
Last showtime init. errors: 0 Last showtime init. timeouts: 0
ATUC ghsVid: b5 00 54 53 54 43 05 10
T1413Vid: 00 00 T1413Rev: 00 VendorRev: 00
ATUR ghsVid: b5 00 54 53 54 43 00 00
[Upstream (TX) Interleave path]
CRC: 0 FEC: 2328 NCD: 0
LCD: 0 HEC: 0
[Downstream (RX) Interleave path]
CRC: 2 FEC: 33 NCD: 0
LCD: 0 HEC: 0
[Upstream (TX) Fast path]
CRC: 0 FEC: 0 NCD: 0
LCD: 0 HEC: 0
[Downstream (RX) Fast path]
LCD: 0 HEC: 0
02-07-2013 8:33 AM
or are you saying that the problem is still present your just getting a better connection now you have changed the psu ?
if its the former then grats
if its the latter well it just shows that old components are always less effective then newer ones (the new one is probably giving the router an extra 100miliamps hence the better connection)
02-07-2013 12:38 PM
The old PSU is marked 12V 1A, the new one is 12V 1.5A, but I thought current was taken rather than given. I doubt the PSU will make any difference once the interference source resumes, earth pin differences probably irrelevant.
02-07-2013 7:05 PM
The 582n arrived. It was useless, it couldn't hold the DSL connection for more than 30 seconds. It wouldn't even let the computer downstairs connect to the wifi for some reason I will analyse later.
02-07-2013 7:30 PM
02-07-2013 7:45 PM
[tt]xdsl info expand=enabled
Physical Layer Statistics:
Modem state: up
Up time (Days hh:mm:ss): 0 days, 0:00:31
xDSL Standard: ITU-T G.992.5
xDSL Annex: Annex A
Channel Mode: Interleaved
Number of reset: 11
Chipset Vendor info (G.994.1): Local Remote
Country code: B500 B500
Specific: 0000 0510
System Vendor info (showtime): Local Remote
Country code: 0F00 0000
Specific: 3C61 0000
Bearers generic info DS US
Payload rate [Kbps]: 2766 564
Attenuation [dB]: 63.5 36.5
Margins [dB]: 6.3 6.1
Output power [dBm]: 17.7 11.8
Number of bearers: 1
Bearer 0 DS US
INP [DMT symbols]: 0.26 2.13
Delay [ms]: 2.77 5.33
Depth []: 4 0.00
R: 12 0
G.997.1 Statistics (Current):
Failures:
Line failures Near end
Loss of signal (LOS): 0
Loss of frame (LOF): 0
Loss of power (LPR): 0
Performance monitoring:
Line PM: Near end
Error second (ES): 220
Channel PM: Near end Far end
Bearer 0:
Code Violation (CV): 902 0
FEC: 5197 109
ATM data path PM: Near end Far end
Bearer 0:
HEC violation count (HEC): 999 N/A
[/tt]
02-07-2013 8:06 PM
Does the one you have got, have a USB port or not, and what version Firmware is on it?
Also if you connected it up when the interference was present that'll probably account for the poorer sync speed.
Just reviewed the thread, and because you haven't mentioned and I haven't asked, thought it would be worth checking - the wiring to all the sockets, is it CW1308, ie the wires colours for terminals 2 & 5 is Blue+white trace & White+blue trace for all sockets?
02-07-2013 9:08 PM
I am assuming the older wifi adapter that couldn't connect was due to its inability to handle the long SSID, considering it seemed to be transmitting all manner of junk non-printable (as in not in ascii range, not as in my opinion of the 582n) characters in the SSID field.
Unfortunately 2 of the internal sockets are difficult to access, the easily accessible one currently has the netgear plugged into it.
And the netgear managed to sync with a speed of 3212 with the interference present.
Edit: I forgot to mention that my neighbour who also has the problem, apparently today their landline phone no longer works properly, I think openreach will be out to fix that tomorrow.
03-07-2013 12:01 AM
On the PSU issue, I expect the new one is running at a slightly different switch frequency, probably better designed and as it's not running as near to maximum rating, it's probably chucking out less noise, hence a slightly better speed.
I suppose you know about all the other "features" to turn of or disable on the 582n?
03-07-2013 6:29 AM
03-07-2013 6:38 AM
Doesn't like TSTC exchange chipsets? It's a bit unfortunate then that most stats I see posted on these forums are either TSTC or IFTN. I saw my exchange is scheduled for MSE Migration this month, the spreadsheet implies it will involve unplugging and plugging end users into the new equipment, so I suppose the TSTC might change.
We live near the edge of a fairly large town, getting a high score in a speed test isn't particularly compelling, being able to browse the web reliably in the evenings is what I'm trying to fix. Which was fine until Wednesday last week. I suppose I should wander around with the short wave radio (10MHz etc.) before considering FTTC!
Edit: I thought the air band radio had short wave, but it doesn't, only air band / marine band above FM. The radio with short wave is rather bulky and I probably don't have that many C or D batteries.
