Slow Broadband
Fletch79
Slow Broadband
Good morning,
Been noticing i have a slightly slow connection over the last few days.
Usually Getting constant download speed of ~700kb/Second on usenet, this has dropped to ~400KB/Second
So I've run a BT Speed test (attached) for some reason i could not perform test 3 even after changing my username in my router
And i've got the stats from my router(also attached)
I've just changed my router settings to allow the TBB Meter again
It looks like my 6.8ish connection is running at 4.5ish
My Router is a Draytek Vigor 2710Vn
Where do i look now?
Fletch79
Re: Slow Broadband
So i've seen a reduction of a third ... but BT says that is still fine?
Fletch79
Re: Slow Broadband
Was Anything done at plusnets end last night?
It appears my connection took a step change about 1.30 am and is ALMOST back to where it was!
Fixes: 10
Re: Slow Broadband
Did you check if the current line speed on the portal matched the IP Profile reported by the BT diagnostic test? It was probably a delay in that updating that was holding you back.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Fixes: 5
Re: Slow Broadband
Yep, bingo:
Date BT Product Profile Event
2013-10-09 18:22:12 WBC MAX24 mb/s (ADSL2+ Annex A) 448kbit/s Upstream Generic Speed 6000 No Time OutSpeed update by Delta Report
2013-10-05 04:11:20 WBC MAX24 mb/s (ADSL2+ Annex A) 448kbit/s Upstream Generic Speed 4300 No Time Out Speed update by Delta Report
2013-10-01 18:09:35 WBC MAX24 mb/s (ADSL2+ Annex A) 448kbit/s Upstream Generic Speed 6200 No Time Out Speed update by Delta Report
2013-09-30 20:59:15 WBC MAX24 mb/s (ADSL2+ Annex A) 448kbit/s Upstream Generic Speed 5900 No Time Out Speed update by Delta Report
2013-09-14 18:08:16 WBC MAX24 mb/s (ADSL2+ Annex A) 448kbit/s Upstream Generic Speed 6200 No Time Out Speed update by Delta Report
2013-09-06 19:54:25 WBC MAX24 mb/s (ADSL2+ Annex A) 448kbit/s Upstream Generic Speed 6100 No Time Out Speed update by Delta Report
Kelly Dorset
Broadband Service Manager
Fixes: 10
Re: Slow Broadband
Capped upload I see!
Fletch79
Re: Slow Broadband
Which was supposed to be lifted in Feb!
dick:quote
Fixes: 5
Re: Slow Broadband
Yeah, you requested it in Feb on Ticket: 67197335.  One of the DC guys or Dave will place the uncap for you.
Kelly Dorset
Re: Slow Broadband
That's been placed for you, not sure when it changed to capped as the data doesn't go far enough back.
It will complete tomorrow.
Edit -
Can you post your router stats, the order I placed failed as it's already showing you as having an uncapped upload.
Fixes: 5
Re: Slow Broadband
The BT supplier product is our system probably hasn't been updated to match.... and because I pasted it... confusion!
Kelly Dorset
Martin99
Re: Slow Broadband
Quote from: Kelly
Quote from: Fletch79
Quote from: jelv
I've been with PN a week or so, and have been very disappointed with my upstream speeds. Had ~1400kbps with old ISP (yes, Annex M, I know). I thought 443kbps with PN was so low I raised it as a speed fault ! (Question #75619131.)
(Looks like I should have come on here, first.)
Now I see that it looks like part of the standard profile? Explains why my upstream noise margins are now ~28.5 vs ~6 dB before.
Is there anything I can do to get this raised (as implied by Fletch's comment), or will the fault I've logged trigger this off anyway?
cheers, Martin
PS apart from this, pretty pleased with the service so far, in case anyone's wondering.
Re: Slow Broadband
@Martin99
I've placed an order to uncap your upload, this will complete tomorrow for you and should see your upload move to around 1Mb/s.
Fixes: 10
Re: Slow Broadband
Why after all this time are you still provisioning customers on capped upload?
Martin99
Re: Slow Broadband
Quote from: chrispurvey
@Martin99
Fab, thanks.
Great service.
cheers, Martin
Fixes: 5
Re: Slow Broadband
Quote from: jelv
We haven't changed the system yet.  It's on the list to do.
Kelly Dorset
