Question #77930724 No response
- Re: Question #77930724 No response
- « Previous
- Next »
09-12-2013 11:13 AM
09-12-2013 4:16 PM
"Dear Mr Sullivan,
I tried to call you today but there was no answer on the mobile.
I have tested the line and currently the speeds seem very good at around 16- 17mbps.
I can see your speed has varied between 13.5Mbps and 17.5Mbps over the last few months.
It is a rate adaptive line, which means it will vary the speed according to line conditions. As long as the synchronisation speed remains above 15.5mbps, then it is not really seen as being a problem. The line rate is usually around 85% of the synchronisation rate.
Therefore, all seems well at the moment.
Please monitor now and just get back to us if any more problems arise.
This ticket will close automatically after 14 days, therefore you don't need to reply if there are no more problems."
So, thinking everything was ok I closed the ticket.
Shortly afterwards, I received a text from my wife to say internet was down. I checked on Thinkbroadband checker I have set up and she was correct.
Since then the SNR has reverted to 6, according to my router.
Can someone check this for me and see why the SNR reset to 3 hasn't worked?
Getting rather fed up of all this hassle
09-12-2013 4:49 PM
If you run routerstats to monitor the noise margin we'd have a better idea of what is going on. If the noise margin varies by approaching 3db attempting to run with a 3db target would be foolish.
09-12-2013 5:14 PM
When I was with BE, my speedtests were always over 16Mbps, and I had 2 disconnects in 4 years of being with them. I only left because they were being taken over by Sky
Wish I hadn't bothered if this is all I can expect
10-12-2013 11:46 AM
Also, can anyone suggest something straightforward that can get SNR stats as my router isn't supported by Routerstats
10-12-2013 12:04 PM
Edit: and if it doesn't work it's highly likely John would add the support. See http://www.vwlowen.co.uk/internet/betatesters.htm
10-12-2013 12:31 PM
I've just tried another one, so you may notice a disconnection shortly when it kicks in.
10-12-2013 12:40 PM
10-12-2013 12:51 PM
10-12-2013 1:11 PM
10-12-2013 1:12 PM
10-12-2013 1:20 PM
Quote from: jelv If the noise margin varies by approaching 3db attempting to run with a 3db target would be foolish.
We already know it varies by 2.2db!
I don't think this is going to work!
10-12-2013 5:56 PM
10-12-2013 7:06 PM
11-12-2013 1:57 PM
Thank you to everyone who helped
- « Previous
- Next »
