Profile reset
- Re: Profile reset
Profile reset
26-03-2014 11:15 AM
Can I get a profile reset please?
BTW show it at 69, but Plusnet is on 53.
Thanks.
Thanks.
Message 1 of 4
(548 Views)
3 REPLIES 3
Re: Profile reset
26-03-2014 11:23 AM
I've updated your Speed Profile for you.
When I was checking your line, it was indicated to me that there could be a possible line fault. I would strongly advise raising a fault with us at http://faults.plus.net so we can get this investigated for you.
Message 2 of 4
(332 Views)
Re: Profile reset
26-03-2014 11:32 AM
Hi thanks for that.
It is possible it is a line fault, I am trying to find what the absolute best effort my line can handle. With the PN estimates saying 47 but then BTW saying 55-69.
Could the fault be the reason for erratic single threaded downloads? Or is it simply syncing too high for the line?
I'll raise a fault in any case.
Message 3 of 4
(332 Views)
Re: Profile reset
26-03-2014 11:36 AM
Well, from what I can see, the line is erroring heavily, so it could be a case that the line is connecting higher than we would expect, however we'd want to make sure you're getting the best speeds possible whilst maintaining a stable connection.
It's certainly worth us taking a look anyhow.
Message 4 of 4
(332 Views)
