Profile problem (again)?
- Re: Profile problem (again)?
- « Previous
- 1
- 2
- Next »
18-09-2009 9:06 PM
19-09-2009 12:54 AM
Quote Download speedachieved during the test was - 2331 Kbps
Additional Information:
Your DSL Connection Rate :8128 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 2500 Kbps
20-09-2009 9:35 AM
20-09-2009 11:33 AM
21-09-2009 7:36 PM
Will be happy when it is back working again as found a s.o.b. fault in upstairs wiring this afternoon (wires looked ok but upon attempt to remove and refit the wire just broke away). Got me thinking the sky box (linked via telephone cable) was causing it when plugged in the router resync'd. Very busy upstairs and down checking and reterminating connections, bandpass filters everywhere, wires etc...
BT speedtester doing what it does best, i.e not working, so just waiting for my BT profile to catch up with my in-house sync of 8128kbps as well as my Plusnet profile currently at 6000kbps
<nudge, nudge>
23-09-2009 4:18 PM
23-09-2009 4:21 PM
24-09-2009 9:29 AM
24-09-2009 10:42 AM
24-09-2009 10:45 AM
25-09-2009 9:04 AM
Typ. 6.5Mbps now glad to say but got this too: http://www.mybroadbandspeed.co.uk/results/05152970.png
With regards to noise margin, what are acceptable levels? Mine (DS) is mostly at 12db (sometimes 11db).
Cheers James
25-09-2009 9:16 AM
- « Previous
- 1
- 2
- Next »
