Problems connecting
- Re: Problems connecting
Problems connecting
02-09-2007 9:57 AM
02-09-2007 11:40 AM
I believe that tremor affected services which presumably needed to be repaired - perhaps the repairs had unwanted side-effects?
02-09-2007 11:44 AM
02-09-2007 1:27 PM
Is this BT notice (Manchester Area Multiple MUXs : Loss of Service) relevant to your exchange?
02-09-2007 1:39 PM
I don't come under the area codes - I am 016188 - but this could definately have something to do with it. I was also having problems connecting most of yesterday (sat).
Has been ok for the last hour...
03-09-2007 10:50 AM
Have raised a ticket with metronet portal but can't even log into that this morning (from work)!!! Argh!
Our modem dsl light is always on - so there is an adsl signal.
03-09-2007 11:00 AM
I'll try giving you a call to see if we can figure out what's going on.
03-09-2007 11:06 AM
03-09-2007 11:18 AM
03-09-2007 11:20 AM
03-09-2007 11:25 AM
BTW, what's a woosh test?
03-09-2007 11:26 AM
03-09-2007 11:41 AM
03-09-2007 11:47 AM
*edit*
Just tested and it let me straight in, the username is the same as the one you use on here can't give the password out for obvious reasons.
03-09-2007 11:51 AM
