Problem connecting to Mychart
Re: Problem connecting to Mychart
@Townman
I can confirm I can connect to the service via a web browser and telnet on port 443 (https) using my Vodafone connection,
If I recall correctly you have Zen connection, do you get the same ping and trace router results?
EDIT:
an end point not responding to pings ought not to stop a trace route 'walking' the path
If tracert is using icmp I'm not sure how it will finish walking the path as you put it
Fixes: 251
Hi Dan,
The business premises has a Zen connection**, whilst home remains with Plusnet. were you think of @jab1 who is indeed with Zen?
**Remote prodding of the router does not expose any router functionality to ping from the router, so I cannot test connection from that provider.
A restart of a person's home router to get a new IP address and thus re-establish connectivity indicates (to me) a firewall (for some reason) is blocking the end-to-end traffic. A traceroute using TCP packets would be required to get further (IMO).
@Anonymous
A refresh of IP Address to a different network range would suggest a routing issue, which firewall are you referring to? can't be the plusnet supplied Hub that is not configurable, for the Hub Two it can either be On / Off / Block all (only allowing inbound port forward traffic.)
It would be interesting to see if trace route to 157.203.6.154 using TCP works, if I have time I might give it a go using my vodafone hotspot and a Mint 21 desktop as Linux traceroute offers TCP and UDP options
grundyb
I also had problems with MYchart log-in and contacted Kings College Hospital London who suggested it was my ISP when I told them it was PN. I dropped Wi-Fi on mobile and went on 4G and was able to log-in with no problem. I then tried my neighbours ISP, not PN, and again able to log-in. Called PN to be told "Factory reset router may help"  Do I really want to factory reset and all that would entail? Stick to 4G in future and forget about even trying to use PC as that has never connected to NHS Mychart.
Pen1
Thanks to everyone who's contributed advice. I've solved my problem by leaving Plusnet (it wasn't the main reason for changing ISP) but I can log in to MyChart with my new provider (Community Fibre).
dave
Fixes: 25
I've just had word that this is now working and mychart.kch.nhs.uk and the other mychart sites should all be working now.
Dave Tomlinson
Plusnet Technology
TonyRob
Thanks, Dave, for letting us know.
Yes, the MyChart app and access via the web page now both work for me when connecting via WiFi.
Best, Tony
Pen1
Many thanks and best wishes
pvmb
Champion
Fixes: 17
Oh no it isn't!
Hmmm… can't reach this page
mychart.kch.nhs.uk took too long to respond
Try:
Search Bing for mychart kch nhs uk
Checking the connection
Checking the proxy and the firewall
Running Windows Network Diagnostics
ERR_CONNECTION_TIMED_OUT
@pvmb
are you using http or https?
windows test connection on port 80 reveals this
tnc mychart.kch.nhs.uk -Port 80
WARNING: TCP connect to (157.203.6.154 : 80) failed
WARNING: Ping to 157.203.6.154 failed with status: TimedOut
pvmb
Champion
Fixes: 17
Uh, huh!
Using the supplied link - mychart.kch.nhs.uk - picks up the http version by default. Manually editing the link in the browser to https connects perfectly.
https://mychart.kch.nhs.uk
Moderators Note: Full quote of preceding post removed, as per Forum rules
RealAleMadrid
Fixes: 68
@pvmb  KCH works for me with Edge browser on Windows10.  I seem to recall that when it was reported some time ago only one of the mychart site was failing on my connection but only briefly. This doesn't help you much, but Plusnet don't seem to know what has caused the problem either.☹️
Champnet
Fixes: 21
KCH also works for me with Edge browser on Windows10.
Penny
Fixes: 9
@pvmb wrote:
Uh, huh!
Not sure where this (ideally-automatic forwarding) is assigned but guessing by the NHS isp (?)
Had to move the HappyChild site last year to Mythic Beasts https://www.mythic-beasts.com/ (needed the https addresses for site pages) and discovered that MB not only provide free SSL (via Let's Encrypt) but also allow the account-holder to nominate if or how URLs get forwarded/diverted.
eg whether www is included in the web address or not, and whether it's http or https (so there are four options in all).
So if the mychart addresses aren't forwarding automatically to https, guessing that's something for the NHS isp to resolve (?)
* * * joined Force9 on 17/02/98 * * * with PlusNet from 2000 onwards
Superusers are not PlusNet staff but do have a direct line of communication into the business to raise issues, concerns and feedback from the Community.
