Speed Drop
Dev
Speed Drop
Hello
I am on FTTC and had a solid connection of around 72/15 Mbps for years. This has now dropped to 42 /10 Mbps for a month now. I have tried restarting the router to no avail, can someone from PN have a look at this for me.
Thanks a lot.
4 REPLIES 4
Fixes: 392
Re: Speed Drop
@Dev First things first:
If the phone test passes, report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
The above assumes you still have 'normal' landline connection - if you have a SOGEA (internet only) one the only option is to call Plusnet - 0330 123 9123
Dev
Re: Speed Drop
Thanks John. I only have internet my phone line was removed last year.
Fixes: 392
Re: Speed Drop
In that case, @Dev ,  you should call PN Customer Support, as advised. Let us know the result.
Windings
Fixes: 14
Re: Speed Drop
@Dev Hi there, if you Private message me your plusnet account username ill take a quick look into your issue and run a quick line test.
Joe Elliott
