Problem accesssing Quick Books over a plusnet connection
snowbrother
Since last wednesday 10th May I've been unabel to access my quickbooks accounts on line using a plusnet internet connection. Spoken to quickbooks and they have confirmed they are aware of an issue connecting via plusnet. Has anyone else come across this and indeed found a fix?
37 REPLIES 37
adamwalker
Fixes: 223
Re: Problem accesssing Quick Books over a plusnet connection
Hi @snowbrother We've not come across any other examples of this on our side. I've had a look at your account and have a suggestion.
As it involves account sensitive information I've popped a ticket on your account here: https://www.plus.net/wizard/?p=view_question&id=233911720
Please have a look when you can and let me know back on here when you've responded.
Adam
 Adam Walker
TomHolmes
Same problem for me. Fine over 4g but on the WiFi cant use quickbooks app. Had a similar problem with screwfix app last year which suddenly started working again after a few weeks.
plass
Yeh same problem here .. Even tried a new laptop .. QB say its Plusnet
RPMozley
Seasoned Pro
Fixes: 16
The problem with Screwfix may have been the issue of DNS records too large for the router (reported previously in the router section here, if I recall correctly).
Please try using a different DNS service, see if it works properly or just the same. We can then rule in or out that it’s a DNS issue.
That's RPM to you!!
TomHolmes
How do I do that?
RPMozley
Seasoned Pro
Fixes: 16
Instructions are dependent upon what system your device is using. Changing it on router can only be done with the PlusNet Hub2 or third party router, it’s not possible to change on Hub 1.
That's RPM to you!!
snowbrother
I have a version 1 hub so can't update the DNS. But I have discovered that oddly I can access my accounts via an iPad over a plusnet connection. The ipad was I last used to access quickbooks before it stopped working.
snowbrother
Hi Adam
I've responded on the ticket to your suggestion
adamwalker
Fixes: 223
Cheers for that, I've just responded back to the ticket for you, please take a look when you can.
 Adam Walker
snowbrother
Hi Adam I’ve responded to the ticket
adamwalker
Fixes: 223
No worries, I've sorted that out and sent you a reply back.
 Adam Walker
snowbrother
I've done that but still no change
SammyM
Fixes: 101
Cheers @snowbrother
Does it work on none Plusnet connections? and is it only the login site affected or the whole site?
 Sammy M - Sheffield Team
snowbrother
It does seem to be onyl plusnet conenction as I can join over my mobile, although that is also plusnet. As I say I can log in via an ipad on a plusnet connection. I can access other parts of teh quickbooks site I just can't log in. Also if I try and contact them through the website that dosn't work either. The issue seems to be when its trying to validate its me login in or contacting them they can't confirm who I am and then it locks me out.
